Question about Freezers
Freezer frost free
I have a frost free hisense HR6VFF177A,its is all ice up. Had a power cut last Saturday due to storm and all my meat is staring to faw out. Could it be my fuse and if it is where on my freezer is it.
  • 884 Answers
If it's iced up it's not the fuse. It needs defrosting so the air can flow again and refreeze your stock
Check the thermistor, heater and pcb timer, and clean the condenser to check it's not running all the time just to get to set temperature.
Posted on Apr 28, 2014
fridgetech
  • 473 Answers
SOURCE: Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Posted on Nov 16, 2007
SOURCE: Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Posted on Apr 08, 2009
SOURCE: BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Posted on Jul 01, 2009
  • 6 Answers
SOURCE: frost free freezer with ice in the bottom and
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Posted on Jul 11, 2009
SOURCE: BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Posted on May 10, 2010
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
I lost the key for door of my kenmore frost free commercial freezer where can i purchase the key?
Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
KEY (Freezer Door Key)
To buy the part call toll-free at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time, Monday to Friday and Saturday from 8:00 AM to 6:00 PM Eastern time. Mention part PS426673 (Part Select Number).
Good Luck
Aug 22, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Dec 30, 2008 | Freezers
Not cold enough?
is this a chest freezer or upright frost free fridge freezer . nead more info
Oct 19, 2008 | Freezers
Meat freezer burns
Hi,tomonbow
ngafm at your service,
You said,you are getting freezer burn in only two days, right?
Are you putting the meat in proper freezer bags and squeezing
air out as you zip lock the bag?
If you do not use proper freezer bags you will always get freezer burn on meats!
WAIT ! This will not happen in two days!
Seems to me something else has happened to your meat prior to your purchase and it probably is not the freezer at fault.
If it happens to meat that you feel was not frozen when you bought it, check with the store of purchase to see if it came into them frozen before it was put in their refrigerator case!
Most super markets receive cases of frozen meat and then put them in the walk in refrigerator, or refrigerator case to present them for sale to the customers and they defrost in the case.
Then we think we are buying meat that is fresh and never been frozen!
Fresh meat will not freezer burn in 2 days unless it has happened previously to the time you bought it.
Also when you freeze any meat you buy, repack it in proper freezer bags and not just any zip lock bag!
But I believe it happened before you bought it.
And i'll bet it all came from the same store.
that's why some people shop at a butcher shop or Costco type store where the meat is fresher and sells out faster!
Bless you.
ngafm
Please give me a good rating before you sign off.
Thank You.
Let me know the verdict. I think I'm right on target!
Do some investigating and ask the store some hard questions!
Sep 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frige freezer
possibly due to not defrosting. take off rear panel in freezer and check if there is ice build-up on the evaporator. if so, melt off carefully with a hair dryer and appliance will then work. get back to me with what you find if you wish
Jul 13, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Freezers Logo
98 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
