Question about Starbucks Single Serve Brewer, Verismo 580
When my verismo is making coffee the pod breaks open and coffee grounds pour out
I've already returned one of these machines for the same problem and now I have another. They act like I'm crazy.
The lever wont close all the way after I insert pod?
You can move the handle slowly up and down until the coffee pod drops down. Be sure the used pod holder underneath is empty.
Mar 07, 2015 | Starbucks Single Serve Brewer, Verismo 580
Verismo pods are splitting
I would definitely return the pods. They are probably an inferior batch and they would probably exchange them.
Apr 01, 2014 | Starbucks Single Serve Brewer, Verismo 580
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Starbucks verisimo clogged and the spout is shooting off
If your machine is clogging, try running the water through the machine, Press the button that [looks like a little shower icon on the top left] first. May need to do it twice. Do that each time before you put a coffee pod in the Verisimo.
Feb 28, 2014 | Starbucks Single Serve Brewer, Verismo 580
Verismo 801
Sounds like a problem with the pods. Check they are manufacture recommended. When on espresso the pressure will be higher so a
"weak" pod could cause this. Unless the machine is producing too high a pressure. Check also there are no projections that could rip the pod when you close the holder.
Jan 28, 2014 | Coffee Makers & Espresso Machines
What are coffee pods? Someone told me to use them in my coffee machine?
Some coffee machines have the option to either use ground coffee and filters or coffee pods. These are small, sealed containers that have the ground coffee inside. You insert the pods into the machine and click them into place. The machine pierces a hole and the water drips through. It's a much tidier way to make coffee especially if you don't drink a lot of it, so you don't want a whole jug full, rather just one cup at a time.
Feb 25, 2013 | Home
Coffee grounds in my Keurig B40
Over flow from coffee Kcup due to clogged tubes. Clean as per manual.
Dec 30, 2012 | Keurig Elite B40 Coffee Maker
The coffee spout is pouring into the coffee pod collector
I have the sameproblem, I suspect something is blocked but I don't know how to remove the spout????????? Please helP!!!!!
Feb 08, 2010 | Nespresso C100B Essenza Single-Serve...
Starbucks Single Serve Brewer, Verismo 580 Logo
76 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
