Question about 2002 FL70
No running lights when headlights are on
When i turn on running lights on they work fine but when i turn headlights on the running lights go off
    Habit-Forming:
    Scholar:
  • 51 Answers
Get a schematic and check how the parking running lights circuit is wired in conjunction with the flash switch built into many tractors.
There may be a problem with one of the relays or switches in this configuration.
Use a good test light like Dormans LED test light available from Autozone or Advance for about $20
A good factory wiring diagram is a good place to start looking
Posted on Feb 27, 2015
I have brake lights but no running lights
You might want to che k the headlamp switch it controls the running lights and also the headlights i had same problem headlights work but no running lights
Mar 13, 2016 | Cars & Trucks
How to find an electrical disturbance in 1998 ford expedition
Normally this condition is the result of a poor body ground connection. Testing for this can be deceiving. At the static(nothing on) condition, testing can show a good ground. However when a circuit is excited, it has a determined resistance and a set current flow. If the ground connection to this or a branch circuit is loose, corroded, or broken wire. This will allow just enough connection to show as being good, but not good enough to complete the circuit with the required amount of connection when energized.
Nov 30, 2014 | 1998 Ford Expedition
1984 Chevy Suburban tail lights not working
Check the tail light bulbs, check to make sure the dash lighting switch is turned up but not turned so far up that the interior lights come on when the door is closed.
Jul 22, 2017 | Chevrolet Suburban Cars & Trucks
I have a2004 roadking classic running lights not working light fillament looks okay headlight and turn lightwps work fine are they on a seperate fuse if so where is it located?
depending on what you are calling running lights as many peopel call differetn things by different names, check your accessory and lighting fuses in the fuse block
Oct 16, 2012 | 2004 Harley Davidson FLHRCI Road King...
I have a 2003 chevy cavalier. headlight issue
The blinking light is telling you that you have a headlight out, if you look the service light should be coming on when the light stops blinking.
Replace the head light and all should be fine.
Feb 23, 2010 | 2003 Chevrolet Cavalier
2002 Dodge caravan headlights wont work
your daytime running light module could be bad.there is also a headlight relay,and the switch could be bad,do the high beams work?click the switch a few times maybe it is jammed.
May 23, 2009 | 2000 Dodge Caravan
93 chev Blazer
perhaps i missed something here... lowbeams and daytime lights are about the same.... be that as it may... the merely obvious thing is that the low beams are burnt out.... next thing would be that the relay for the day time lights could be defective... it's often mounted on the firewall.
Robert
Nov 12, 2008 | 2001 Chevrolet Blazer
2002 FL70 Logo
173 people viewed this question
Top Freightliner Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Freightliner Vehicle Part and Accessory Expert? Answer questions, earn points and help others
