Question about ETL Secure Logic 20710 Keypad Wall Vault
Keypad does not work
Need to reset keypad
My keypad used to work, changed battery, does not work, bought new keyless pad and still wont work, remote in truck works
Need to reset/re-program it as specified in the user manual. When the keypad loses power during the battery change it loses the original settings and need to be reprogrammed. New keyless pad also need to be programmed to link with the receiver.
Jan 12, 2016 | Building Materials
HOW TO RESET THE SECURITY CODE IF MY KEYPAD IS NOT WORKING
If your keypad isn't working there is no way to reset the code.
Oct 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Need master reset for sgh t669
Hi
Try this one *2767*3855# and it perform a full wipe and reset make sure you take the sim out first
May 20, 2011 | Cell Phones
Trying to reset a new 4 digit code in my wireless remote Sears 139.53754 but I dont know the current code which the instructions say I need in order to reset. I tried the smart button on the motor unit...
You don't need the current code. What you need to do is press and immediately release the smart button and then walk over to your keypad and enter any 4 digit code you like. If this doesn't work your keypad is bad.
Aug 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to know how to reset keypad for garage door.
If you pressed and immediately released the smart/learn button and then walked over to the keypad and keyed in a 4 digit code and it doesn't work then the keypad is bad. The model number for the opener is on the door side of the motor unit and starts with 139.
Mar 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
I had to unplug the system and when I plugged it back up the keycode pad no longer works i want to reset it
This isn't a normal occurrence. The keypad doesn't need to be reset because you unplugged something. You can try programming it anyway by locating the smart/learn button on the rear of the motor unit. Press and immediately release this button and then walk over to your keypad and key in your four digit code and press enter. Be sure to also check the battery inside the keypad.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my keypads outside? My battery
There is no reset. You can try programming it and see if that works. If not it is probably dead.
On the rear of the motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in your four digit code and press enter.
Oct 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Number 7, 8 & 9 key is not working
change your keypad or clean keypad.
Feb 21, 2008 | Nokia 6600
ETL Secure Logic 20710 Keypad Wall Vault Logo
77 people viewed this question
Top ETL Home Security Experts
Lawrence Oravetz
Are you an ETL Home Security Expert? Answer questions, earn points and help others
