Question about Hitachi ED-X3280 Multimedia Projector
Lamp not working
Lamp remains red
I recently replaced the lamp - part # 915P061010. But the TV powers off about every 20 - 30 minutes / red status lamp is illuminated. At times the TV will remain on for hours. But eventually the TV...
It looks like your ballast board is going bad, this is a common problem for DLP TV's the ballast board is the power source to the lamp and if for any reason this board does not send enough energy to the lamp it will turn off, It looks like your ballast it starting to get weak it gathers enough energy to turn on but gets weak again and turn back off you have a new lamp and it requires for the ballast to be working at it's full potential
Sep 13, 2010 | Mitsubishi WD-57734 57" HDTV
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Resetting the lamp timer to zero
some times the lamp cover switch is broken or not setby the cover ,this wil shut off power on button
May 27, 2010 | Sharp XVZ200 Multimedia Projector
Replaced both bulbs with brand-new bulbs. Now all
Verify that the lamp doors are securely closed. The blinking red lights indicate a lamp problem. In this case, both appear to be defective. I doubt that the lamps are the problem. double chack all connections and doors for proper seating. Update this if the problem remains.
Thanks,
Dan
Apr 16, 2010 | Sharp XG-PH50X Multimedia Projector
After replacing lamp the red lamp light remains on. Lamp will come on for a second then go out. About a minute later the red lamp light comes on and unit shuts off.
Check the lamp door to make sure it is seated properly I believe the red light indicates door switch problem. It shows you lamp error data in the service manual.
Feb 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
KP-65WV700 Red and Green Lamps fade out after about 15 seconds
If you know how to adjust G2 (screen) volt adjustment then increase a little bit screen volts of red and green lamp.
Mar 15, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Red lamp lite flashes along with power light.......
That is definitely the Light Engine (also referred to as an optical block) Very expensive.
Dec 31, 2008 | Sony KDF-E55A20 55 in. LCD Television
Lamp and power light flashing
Red lamps flash but picture doesn't disappear. 100hrs remaining on filter timer.
Aug 03, 2008 | Hitachi CP-X345 Multimedia Projector
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi ED-X3280 Multimedia Projector Logo
22 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
