Question about Mirage LF100 Subwoofer
Hooking up my Digital audio subwoofers
I bought a Digital audio subwoofer alone. I hooked it up to my reciver and it sounds like if its not getting enough juice. Connectiongs are 2 for inputs, 2 for speaker, 2 for speaker, and 2 for output.
  • 757 Answers
How did you connect it to your receiver?
Posted on Jun 19, 2009
How should I hook this up to a Sony hi-fi stereo?
I would try going into the menu settings on your receiver to make sure that the subwoofer is turned on or that the volume is turned up. If it is a powered subwoofer you can try hooking the output of a phone or an iPod to the input cable just to test and see if you are getting sound through the subwoofer. If that seems to be working ok then you know the problem lies with the receiver.
Oct 09, 2015 | Sony Audio Players & Recorders
I have an additional subwoofer 10" JBL. How do I go about hooking it up with my sony receiver GX800ES?
That is a capable unit. Do you have a user manual? If not, it is here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRGX800ES&template_id=1&region_id=1&tab=manuals#/manualsTab
In there it says you connect the subwoofer to the "Surround Out - Mono" output terminal.
Nov 27, 2011 | Sony STR-GX800ES Receiver
No sound when hooking receiver to subwoofer using standard red RCA cable. Do I need a subwoofer cable?? I have turned my tuner subwoofer to YES, powered up receiver and subwoofer but nothing.
Probably not if it takes RCA input, but the receiver needs to be informed of the sub's presence and hw you want to share low frequencies among the rest of the speakers and itself. Then you need to set the relative levels using test tones, which also proves the sub works.
http://www.retrevo.com/support/Sony-STR-DH700-Receivers-manual/id/23341dj691/t/2/
Page 102
Set the subwoofer to YES (Page 43)
Jan 17, 2011 | Sony STR-DH700 A/V Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
How do i hook up the wires from and to a sa wms 315 subwoofer
what r you hooking it to is #1 rca wires r the way to go when hooking up a subwoofer up .some subwoofers have 2 rcas on them one input and one output the in put is mono if what your going to hook it to has rcas on it then the left one is a mono output but if its an audio system then it mit have a subwoofer output on it
Jun 29, 2010 | Sony SA-VA1 Rear Speaker
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
Hooking up head unit
the head unit i had all i did was hook the wire up to a ground and it worked fine.
Jun 26, 2009 | Car Audio & Video
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Audio Players & Recorders
Connecting subwoofer to receiver.
have u checked that the sub option on the reciver is on?
Jan 06, 2006 | Kenwood 107VR
Mirage LF100 Subwoofer Logo
228 people viewed this question
Top Mirage Audio Players & Recorders Experts
Ben Armstrong
DaveMc3
DaveMc3
berggei
Are you a Mirage Audio Player and Recorder Expert? Answer questions, earn points and help others
