Question about Pyramid Car Audio & Video
Display door latch broken
Broken from main body front
    Top Expert:
  • Pyramid Master
  • 2,931 Answers
I hate when that happens. Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Posted on Feb 10, 2018
  • 1028 Answers
SOURCE: front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Posted on Jul 31, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: door latch on sharp 1480 microwave over the range oven
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order Sharp parts is Tritronics.
Posted on Aug 09, 2008
MNTECH
  • 1543 Answers
SOURCE: GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Posted on Mar 08, 2009
MNfisherman
  • 11896 Answers
SOURCE: how to replace interior door latch on elantra?
Remove any and all screws from the door panel, including removing lock and window controls. then take a large flat-tipped screwdriver and pry off the panel all the way around. FInally lift panel up and off the door. Now you will have access to the inside of the door. Everything from here is self explainable.
Posted on Dec 07, 2009
leepania
  • 1099 Answers
SOURCE: battery door retaining lugs broken,also the
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Posted on Feb 05, 2010
2005 envoy drivers door wont open from inside or outside
Linda, The door latch linkage is probably damaged or fallen off inside the door. Pop into a good body shop and have them check the door lock/latch mechanism for you. The body shop rates tend to be more reasonable then dealership for this type of repair. Links below are just to give you an idea of what may be involved in repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GMC Envoy door panels remove and install front and rear
How To Install Replace Broken Power Door Lock Front Chevy Trailblazer GMC...
Chevy Truck Door Latch
How chevy door latch works
Jun 22, 2016 | 2005 GMC Envoy
How to fix a door latch of Samsung SMH9207ST microwave?
The small tab on the latch broke so the spring was loose. Took my drill and drilled a small hole in the main body, ran a small wire tie thru it and hooked the spring to the wire tie. Works great and more durable than the orginal dinky hook.
Dec 10, 2011 | Microwave Ovens
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
The door on my Samsung Washer won't latch. It then displays DS error. Seems the roller in latch is down therefore not allowing door to close all the way.
This means your door interlock has broken & needs to be replaced.There made of plastic this is a very common problem with all brands of front load washer's.
Mar 13, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
Hi, no display on any led. 240v to machine sounds
It does sound as if the door latch may be at fault but it also seems as if it has caused the main control P.C.B. and control Interface to fail.This machine was manufactured in April 2005 from the Prod. no.This is covered under the major parts warranty (not the door latch).Also make sure if the power to the controls is off check for any loose connectors on the main p.c.b and interface.Also have a look at the body of the door latch and if there is a brown discolouration that is a good sign that is the culprit.
May 03, 2010 | Zanussi ZWF1440 Front Load Washer
Kenmore HE2T front loading automatic washer...model 110.4756,4757..displaying F22 error message? What does that mean and how do I fix it?
"F22" is a door latch error. It can mean any of the following:
1. The door latch mechanism is broken. Inspect the door latch to ensure it is intact and not broken. Verify the electrical connections are making good contact.
2. The door latch hook (located on the door) is broken or worn. If the latch hook is damaged, it may not allow the door latch to engage and lock properly.
3. The interconnecting wiring between the Central Control Unit (CCU) and the door latch are loose, broken, or not making good contact. The CCU is the main computer for the washer. You will need to remove the top panel of the washer in order to access. Simply remove the retaining screws located in the back of the washer and the panel will slide back, then lift off.
4. Defective CCU. The CCU controls nearly all the functions of the washer, including the door latch. If the CCU fails, the proper lock/unlock signals do not get sent to the latch mechanism.
Determing how to troubleshoot the CCU and Door Latch is in the technical data sheet included with your washer. The tech sheet is located behind the lower toe panel directly below the door. If the tech sheet isn't behind the toe panel, it will be affixed to one of the interior cabinet walls. I do not have the procedure memorized, but there are some tests you can try to determine if the problem is the CCU or latch.
If you determine the latch needs replaced, the following link may assist you:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
The procedures I provided are for Kenmore Elite series front loaders, which are the larger cousing to the HE2. The steps are nearly the same except for how to remove the door gasket from the front facing of the washer. The HE2 models are glued on instead of using a wire hoop (unless yours is a later model and has been modified). You can use a metal putty knife to carefully peel the gasket loose and reseal it when completed. A good appliance gasket cement (found at any appliance parts retailer) will work. You can also use a plumber's sealant. Just make sure you use a pliable rubber cement. Do not use super glue.
Some prefer to try to work through the top of the washer and avoid removing the gasket. This may be possible with the larger top loaders, but the smaller models are usually a bit more difficult to access.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope you find this information helpful.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Open door position hold latch snaps real loud opening and closing the door
The hinge has most likely broken loose from the door frame. Look at the main body where the slider bar attaches to the body from the door. It is common for the hinge to break loose. It will need to be spot welded back into place to stop the clicking noise. Usualy two clicks when the door opens and then when it closes.
Apr 01, 2009 | 1999 Volvo V70
Door will not lock
Faulty Latch ,, i would order and replace the latch assy, you acess the latch by removingthe 4 screws in the dispensor assy, the n remove the door, andthe 2 screws opposit teh door hinge. then the front "u shaped" panel will come off and then just 2 5/16" screws on either side will release the main top assembly allowing you to tip it backwards and gaining acess to the latch assy
Feb 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Car Audio & Video Logo
Top Pyramid Car Audio & Video Experts
Greg Cann
Greg Cann
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
