Question about Nikon SB-700 TTL AF Shoe Mount Speedlight - USA Warranty. - Adorama Off-Camera iTTL Coiled Flash Cord, Heavy Duty Version
Zoom diffuser working - Nikon SB-700 TTL AF Shoe Mount Speedlight - USA Warranty. - Adorama Off-Camera iTTL Coiled Flash Cord, Heavy Duty Version
  • Bart Pulverman Feb 12, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? If the zoom diffuser is working, what is your question?
Text is blinking on my 430ex lcd screen zoom --mm. How do I get it to stop?
Check the diffuser is fully retracted. Pull it fully out then all the way back in.
Apr 10, 2014 | Canon Speedlite 430EX TTL Flash
550 ex zoom stuck on manual
Hi Liz,
Because this thread is more than a year old, I sincerely hope you figured out the solution to the zoom problem with your flash. I was having the same issue with the 550ex and found the simple solution on a forum about Canon Flash Photography.
Make sure that your diffuser panel (wide panel) is off and securely seated in the top of the flash unit. When the wide panel is in the down position, it forces the flash into manual mode at the widest setting.
Hopefully this little tip will come in handy for someone out there reading this thread.
Mar 05, 2011 | Canon Speedlite 550EX TTL Flash
The zoom on the sb600 wont adjust accordingly to the zoom of my lens
Three things come to mind.
First, make sure that you are in fully automatic mode - easily done by reset (holding down "Mode" and "On/Off" at the same time. If you hit the "zoom" button it takes it out of automatic zoom and cycles through manual zoom settings until you get to auto again.
Second - make sure the camera is in an auto mode - manual mode could stop it from zooming.
Third - make sure that you don't have the diffuser pulled down. That can keep it from zooming also.
Mar 30, 2010 | Nikon Speedlight SB-600 TTL Flash
Flash zoom function not working
have you checked that the diffuser is pushed fully home in its slot until you hear a click - this diffuser is for close-up work only and dissables the zoom flash
Feb 02, 2010 | Nikon Speedlight SB-800 TTL Flash
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
430EX
your flash has a diffusion panel in front, make sure its in all the way
good day
yitzy
Oct 19, 2008 | Canon Speedlite 430EX TTL Flash
My speedlite keeps flashing the zoom control and freezes
Make sure the built-in diffuser is pushed in all the way... that diffuser is only designed to work when in "14-mm" mode so whenever that diffuser is down, even just a little bit, the entire display will flash and 14 mm will be shown as the focal length of the flash.
May 28, 2008 | Canon SPEEDLITE 580EX TTL Flash
Zoom range 14-17mm
make sure the diffusion dome and the built in wide angle adaptor are off. If the diffusion dome is on, it will only work as 14mm and 17mm without the diffuser but with the wide angle panel.
May 10, 2008 | Nikon Speedlight SB-800 TTL Flash
Spot on pictures
Well short answer to your dismanlter question is do not. Contact Canon for a repair cost - this is fine lab work not for the kitchen table.
Aug 19, 2007 | Canon PowerShot A520 Digital Camera
Nikon SB-700 TTL AF Shoe Mount Speedlight - USA Warranty. - Adorama Off-Camera iTTL Coiled Flash Cord, Heavy Duty Version Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
