Question about Samsung HL-S5086W 50" HDTV
Fan motor for the dlp lamp is making a loud sound and the fan isn't turning properly
    Genius:
  • 1,139 Answers
Hello terryc815, The fans are about to malfunction and should be replaced, as soon as possible. I would like to suggest that you get a qualified TV technician to do this since there is a chance of damage to the light engine if you attempt this repair yourself. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 16, 2009
Samsung HLR5064W DLP TV load vibrating noise like a fan blade hitting something, lamp light is one, Tv will light up but discolored
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_3_58_01_pm.jpg
Oct 24, 2012 | Samsung HLR5064W DLP Projection TV
Tv making noise sounds like projector motor.
Your cooling fan may be collecting lint. If it cannot run freely, you will lose a projection lamp. Just like a clothes dryer, you must have a good clean exhaust exit to assure proper performance!
Nov 29, 2009 | Vivitek V37655 56" DLP TV
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
HL-P5O63W : Rear Lamp Cover Error!
That my be the color wheel you are hearing
They will make a huge whining noise
The lamp door also had issues the lamp switch must be in the up position when you put the door back on
Feb 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My 61" Samsung DLP has loud Buzzing sound - Everything else ok
There are only 2 moving parts on a dlp tv the color wheel and the fan. The color wheel needs to be replaced about every 4 to 5 years. Some start to make noise and others like mine blow up with a bang. Go to utube to get instructions on how to replace it only cost me for part $100 good luck
Dec 14, 2008 | Samsung DLP HL-P5663W 56" TV
Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Jul 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Open Questions:
Samsung HL-S5086W 50" HDTV Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
