Question about Sony ICF-C1IP (Black) Docking Station
How do I set the time
There is none
Phone rings 4 times then goes to message I want it o keep ringing
Basically, you want to disable Forward No Answer to voicemail:
Feature ** CONFIG
Terminals&Sets
enter ext #
advance past Line Access to Capabilities
go to Fwd No Answer
CHANGE softkey to None
go to Fwd On Busy
Jul 01, 2014 | Nortel Lands Phones
How do you set the time on RC591-A (RCA Docking Alarm Clock)
None of these answers works! When I tried the first option, the clock DID NOT flash at 12:00 a.m. Since that didn't happen, none of the following steps did either.
The second option didn't work either. Holding the set key never made the display go to a colon, flashing or otherwise. Again, using the forward and back keys didn't work as described.
The third option with a link to another website led to instructions on a power tool and had nothing whatsoever to do with the clock on the docking station.
The fourth option doesn't give any instructions after you hit the time you want to set. The time DOESN'T stay where you set it. It once you release the forward or backward keys, it reverts to the original time that was on the clock to begin with.
None of these answers works at all. I was given the iPod touch and the radio docking station secondhand from my sister and she doesn't have either the instruction manual or the special batteries that go in the battery compartment. The clock on the iPod itself is fine. I finally figured out (on my own) how to turn off the danged alarms and timing mechanisms but cannot set the clock.
Nov 07, 2011 | Audio Players & Recorders
Hi, i want to lock my c6 phone with a passcode or password!! becoz of my brothers provoking my privacy??
To activate lock code on Nokia C6:
  1. Select Menu
  2. Settings and Phone
  3. Phone mgmt.
  4. Security settings
  5. Phone and SIM card
  6. Select Lock code
You can also set the phone autolock period to avoid unauthorised use, set a time-out after which the device automatically locks. A locked device cannot be used until the correct lock code is entered. To deactivate this option, select None.
Jun 29, 2011 | Nokia C6 Smartphone
Moved the mirco wave, then the only buttons that work now are the time set, but it only shows 12hr and 24 hr, and will not set the time. none of the buttons will work now for the cook time. if the power...
i cant work out if its broken or not over the years i do remember seeing a sanyo microwave that would not cook untill the time was set though have not seen another since (cause its a silly idea) but try setting the time and it might work
Oct 14, 2010 | Daewoo KOR-860A Microwave Oven
Says date/time not set but wont let me set the time or date!
Broken keypad ribbon. It's because the keypad ribbon is folded over twice and the creases split over time. have a look at my tips page for this problem. It won't help you much I know and the only solution is a replacement membrane.
May 04, 2010 | Fuji FinePix F470 Digital Camera
How do i set time on unlisted watch
dear sir
there r three buttons in which there r combination of buttons. your stopwatch button may not set the time . the middle button may set the time for u
Apr 09, 2010 | Kenneth Cole KC2315 watch
Point setting on 77 ford
The gap on the points to your distributor is .017 or the thickness of a match book.
Jun 29, 2008 | 1982 Ford F 250
Dialogue - Not Audible
The dialogue comes from the center speaker. If you have a center speaker make sure that that it is connected correctly. If it is them check the speaker configuration setup menu. Make sure that the center channel is set to small. If it is set to none you will get no dialogue. If you don't have one make sure that it is set to none. Make sure that you have the speaker levels set correctly according to the manual. Lastly check the tweeter in your center channel is not blown.
Oct 23, 2006 | Onkyo TX-DS989 Receiver
Sony ICF-C1IP (Black) Docking Station Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
