Question about Arrowhead Brass PK1390BCLD Vacuum Breaker 3/4 Hose Thread Self-Draining - Each
Hose faucet leaking
Brand new, but still leaking from the holes
I need to replace the hot water handle
A picture, model, or brand of the type of faucet you have will be helpful as there are only three types of faucets. One hole, two hole, and three hole faucets. The one hole ones have two types: a single hot or cold, or a mixer valve to combine hot and cold into a single faucet. Each have a surface mount or wall mount version.
They all follow the same similar installation method. Turn off water supply. Unscrew supply lines from supply to underside of the faucet. a Plumber's wrench is needed or a spanning crescent wrench to remove the supply lines.
-Unscrew whole assemble from the sink.
-insert new one into the same hole as old one.
-from underneath, install the new faucet using the supplied hardware.
-Use plumbers tape (Teflon tape). It's often a white or pink silicon tape around the threads prior to screwing the supply lines back in. Re-connect the supply line.
-Open hot water faucet to maximum. Slowly turn on the water supply. Watch for leaks and drips. If any close the water supply and undo the supply leads and apply more Teflon tape.
- to apply tape. Start at the end and pull tightly, wind the tape into the threads in the direction of the turn. Do not wind in opposite direction.
-Try to turn on water again, turn slowly until it is at maximum, watch for leaks and drips.
-now slowly close the faucet and continue watching for leaks and drops.
If the faucet is fully closed and there is no leaks, you've done a good job... basic plumbing 101.
Now if your pipes are solder types and not screwed in supply line, and you're not confident with a torch or have little experience, ask for help from a friend who has some torch knowledge or hire a plumber. It is simple to do but requires a lot more steps than simply screwing in and unscrewing supply lines.
Aug 30, 2015 | Plumbing
Water leak at base of faucet on granite and onto hose under sink. its coming from the faucet not the hose.
You don't mention the brand but most faucet Mfgrs have rebuild kits.
May 26, 2015 | Home
My hose has a hole in it
which hose, faucets and where is the hole? You may spray leak seal if the hole is small or change the hose before you get more problems
Oct 10, 2013 | Plumbing
Spray hose is leaking at top
Re tighten your hose connector and repair the leak of replace with new one
Jan 11, 2011 | Hansgrohe 06649860 Solaris Single Hole...
The hose running thru to the faucet head has severe leaking. Can this be repaired?
yes the hose can be replaced, this is a off brand, if you remember where you got it, you can order a new hose...
Pleas rate/vote this response thanks
Dec 19, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
I have a kitchen sink faucet that is leaking water from the back part of the faucet. There is a hole there and the faucet leaks water, when the water is on. Why is it doing this?
If it is a rusted hole get new faucet, but on many faucets that is where the Sprayer connects. Check for loose Sprayer hose at faucet under the sink.
Sep 14, 2009 | Plumbing
Problem of leakage with a new Grohe bathroom fauce
what part of the hose? on some grohe's there it an o-ring on the end that threads into the bottom of the faucet that sometimes can leak if not installed right. but replacements can be found through your local wholesaler, not home depot or any hardware store.
Aug 17, 2009 | Plumbing
Leaking faucet ff1280r846,1200r692underneath,when lever is open water is running below off spray nozzle..
hello. pull out the spray nozzle and turn on the water. The water is either leaking from the hose, or from the connection. If the hose has a hole in it you will have to replace it. If the connection is leaking, disconnect it [with the faucet off], put some teflon paste or teflon tape on the threads and reconnect it.
Aug 16, 2009 | Plumbing
Have b & K frost free antisiphon hose bib that leaks out of seal
You can replace with any brand frost free faucet.Parts are impossible to get.
Jun 14, 2009 | B&K Plumbing
Arrowhead Brass PK1390BCLD Vacuum Breaker 3/4 Hose Thread Self-Draining - Each Logo
80 people viewed this question
Top Arrowhead Brass Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Arrowhead Brass Garden Expert? Answer questions, earn points and help others
