Question about Canon PIXMA iP4000 InkJet Photo Printer
Problem with color quality - Canon PIXMA iP4000
Printer was working fine until yesterday.  All of my photos are printing with a heavy yellow tone  -- this is making all of the colors in the photo looked washed out.  I went through all of the cleaning options and nothing has worked.  Any ideas?  Thanks!
  • 2 more comments
  • dclem Oct 30, 2007
    Thanks for the info night71.  When I try a test pattern, all of the colors look faded.  This problem started to happen after I replaced the Magenta and Cyan cartridges.  I bought the Office Max brand of these cartridges (vs. the Canon branded ones), so maybe that's contributing to the problem?  Do you still think it could be the cable?  Thanks again!
  • dpost Nov 15, 2007
    All of the colors are coming out or printing slightly faded on both my ip4000 and my ip6700. I tried a number of things like cleaning the printhead and changing the cartridges but nothing helps.
  • cjmanc Jan 20, 2008
    I have the same problem - I've changed all the cartridges to the same brand - admittedly, not canon, but is this really how bad it gets when you don't use their brand??  I've changed the cable, I've cleaned the printing heads - nothing works.  Please help!!!
  • Anonymous Nov 24, 2008
    Printing a greeting card the fall orange colors all came out green
I had this problem... its the ink! Check you are using magenta and NOT "photo magenta", and also that you are using "cyan" and NOT "PHOTO cyan"... basically photo cyan, photo magenta and photo yellow are not designed for the ip4000, if you check the smallprint on the box it does not list the ip4000.
This exact problem happened to me and it was driving me crazy. I think the "photo" versions of the inks are for printers that take two tanks of each colour, and the photo version is used for very subtle colours... so if you are ONLY using these inks, photos will appear washed out, yellow etc
Posted on May 16, 2008
  • 328 Answers
If you print a test pattern, do all the colors show clearly? It sounds like the cyan and magenta may be running low which means that the ink in general is low and needs replacing. If the colors come out normal during the test, it could be the USB cable itself. Although it seems to connect, a faulty USB cable or port may not be functioning properly. Try another port and a new cable if you have all colors.
Posted on Oct 30, 2007
  • Lyle Siemens
    Lyle Siemens Oct 30, 2007
    I see, after you replaced the magenta and cyan, it happened. It is recommended to change all cartridges to the same brand. Canon is best but may not be compatible with Office Max ink. I would suggest replacing the yellow with an Office Max brand too just to keep the same type of ink together. The USB cable has been known to cause very odd symptoms when its faulty such as little or no color, streaks one color images and so forth. If you have an extra cable laying around, you can try that or if a friend has one. But try replacing the yellow first, at least you can return the ink if its bad.
Pixma ip4000 prints blue instead of green
The fault could be -
The yellow cartridge is empty
or
The yellow ink nozzles are blocked
Because green is made up with blue and yellow colors.
Sep 12, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I CHANGE COLOR CARTRIDGES, CYAN AND MAGENTA. NOW,
1) If you've used generic compatibles, that could be the issue.
2) Check out the printer settings for quality, colour and photo correction..
Mar 14, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon ip4000 was working perfectly until yesterday. Suddenly it won't print the correct colors. Sometimes the nozzle check looks perfect, sometimes some colors are low, sometimes colors are mixed...
It could be a few different things but letys try the easiest first. Go into control pane/jprinters/ and do a deep nozzel cleaning. leave the printer idle for about a hour or two before trying to print again. You may have to repleat this procedure. If this does not fix your problem it could mean that you need to update a driver for your printer or that you have changed your colour settings in a graphic program such as adobe. Failing all else you may just need brand new cartridges. I have a canon i860 and found a very inexpensive site online to order the cartridges for a few dollars each. even if you don't need the cartridges right now check out the site and stock up.
http://www.piloshop.ca/index.php?main_page=advanced_search_result&search_in_description=1&keyword=canon+i+series+cartridges
Jan 09, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I am having a problem with my Canon PIXMA iP4000. My black does not print properly. If I go through the nozzle cleaning I get 1 or 2 good pages, then the quality deters. By the time I get to page 5 or 6 it...
It sounds like you have a faulty black cartridge. Have you tried a OEM cartridge? Sometimes aftermarket/refilled cartridge inks are not up to specs and gum up the nozzles. It sounds like the problem you are having.
Aug 31, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip 5000
If the print head moves left and right smoothly on the paper as it is printing and all the other colors and black print is ok the surely the Print Head is faulty, get it replaced and your printer will be OK.
Regards,
Joseph Manoj
+91 9352008418
Jun 28, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
IP4000 Color prints look washed out/yellow
Check the custom settings in the printer properties. Try playing around with different settings till you find the one that suits you best..
May 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer problem
Hi , did you check nozzle what color appear , some ink cartidge are old stock and dry , pullout cartridge clean the contact nozzle .
Feb 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
877 people viewed this question
old marine
old marine
