Question about CAD Microphones GXL2200 Professional Microphone
How to fix gxl 2200 microphone sound through device
Gxl 2200 microphone device plugin, the mic volume is ecohing
My Mic is on all the time it is also coming through the speakers so when i turn external speakers on there is an huge feedback
See Adjust volume below
To use any microphone with your computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and the volume slider is at the top of the scale.
Ensure the MUTE ALL box isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Feb 10, 2011 | Toshiba (P000257700) Microphone
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
My pc is not picking up my mic from the mic slot?
Control Panel/Sounds and Audio Devices/Volume/Advanced/Playcontrol/Options/Properties/Playback ( check microphone )/Recording ( check microphone) set your volumes. Also make sure your devices are set in the Audio tab.
Aug 02, 2009 | Audio Players & Recorders
I bought a GXL2200 and i cant hear my vocals.
The GXL 2200 is a condensor microphone. It needs Phantom power to operate, and get the correct levels for recording. Your lexicon interface should have a button/switch that says +48V phantom power, or something similar. This needs to be enabled before the GXL 2200 will work.
Mar 07, 2009 | CAD Microphones GXL2200 Professional...
Mic problems
Go into the Control Panel and select Sound and Audio Devices.
Choose the tab Audio and then select under Sound Recording the Volume Button.
UNcheck any devices other than Microphone (checked). Also, put your microphone level midway.
See if that helps.
Nov 20, 2008 | Microsoft LifeCam VX-6000 Webcam
Gxl 2400 wiring connections
well best to just resolder it if you know the wire it should have a standard diaphragm with standard layout. should be asimple fix.
thanks,
Nate
Aug 12, 2008 | Audio Players & Recorders
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Realtek audio device with sound effect menager
First thing is first, there should be 3 audio jack inputs. Line in, Line out and Mic. Make sure you are plugged into the Mic input.
Next if you are running windows XP check to make sure the Microphone volume is not muted and turned up. Do this by going to control panel --> Sound and Audio Devices --> volume tab --> Advanced button. The Microphone volume should be there if not select file --> properties and make sure microphone is checked. It should then appear on the volume controls.
This should take care of it if not what program are you using the mic with?
Feb 21, 2008 | Dell Dimension 3000 PC Desktop
Microphone are not working
Hi!
it could be a slot issue. to make sure that its not the slot or port, try a known good microphone from a friend or from the store. then if the known good mic still doesnt work, then its the slot or the settings on you sound and game controllers are not setup for the mic. Check control panel and go to sound and audio devices and check the settings for the mic. If the settings are okay then it could be the slot or the port.
Karlox
Dec 03, 2007 | Dell Inspiron 2200 Notebook
CAD Microphones GXL2200 Professional Microphone Logo
60 people viewed this question
Top CAD Microphones Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Miguel Luiz Martins
Are you a CAD Microphones Audio Player and Recorder Expert? Answer questions, earn points and help others
