Question about GPS
Myy 43NT unit suddenly is saying "no signal" (even tho the graphic displays one bar). Unit was purchased less than a month ago. It was working fine until today.
  • 544 Answers
did you try to reset your GPS.
thanks,
Posted on Jun 14, 2009
My 4 month old Samsung suddenly says, when turned on, there is no signal, check connections. They are all fine. I hooked my old television in and it works. What happened.
Who cares what happened...it's 4 months old - it's under WARRANTY.
Any attempt to repair it would void the warranty.
Call Samsung, and they will briefly troubleshoot with you then replace the unit.
Feb 27, 2011 | Audio Players & Recorders
The base unit is turning on and operating, but the parent's unit all of a sudden just won't connect. I know the base unit is working because it is still detecting movement and the alarm goes off when...
Try the manuals: http://www.angelcare-monitor.com/Canada/en/help#tabs-2
The picture showing looks like the AC201 which has a hard switch for the channel selection, but you describe a menu screen which sounds like the AC401 or similar. If it is the AC201 - ensure both units are on the same channel. If it is the AC401 or other unit where there is an LCD, then try the following:
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT: If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and press and hold the MENU button ,the "out of range"indicator will flash and you will hear a beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect. The Tic light flashes.This normally happens within a few seconds and you will hear a bleep to confirm it. If successful, the parents unit display will first show the channel of transmission (C1 to C8), which will be replaced by the room temperature and icons for all activated functions.
Sep 19, 2009 | Angelcare 2009 Movement Sensor Baby...
Sirius Receiver goes silent and displays Acquiring Signal.
I have a 3 year old Sportster 2 replay unit that worked perfect until 1 month ago. I posted my problem on this website a day before you did with this same problem. I googled to no end and even spoke to Sirius who wasn't willing to replace my unit at no charge since it was out of warranty. I found an unusual solution on the internet that worked for me. I place my receiver in the freezer for at least 20 minutes (this was recommended by a guy somewhere on the internet with the same problem). I have actually left it in freezer overnight too. This has solved my problem. It is the craziest thing but I thought I would try it before I resorted to replacing all my accessories and receiver since Sirius was less than cooperative with the issue. Anyway, hope this helps.
Jun 04, 2009 | Sirius Satellite Radio Receiver
Acquiring signal only on display
If under warranty get a replacement. If not, you are beat, they are dead when they stop getting signal and you have tried different antenna. It's sad but true.
Jan 21, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Cold Blooded Stereo
Switch the input wires from the sub to the speaker amp and vis versa. See if the problem switches to the other amp. If it does, you know you have a fault in the head unit. If it stays in the same amp, then you know you have a problem in the amp unit. Check with the manuufacturer online about how long the warranty is on each unit. Maybe they are still covered. Good Luck Please do not forget to rate this thread.
Nov 26, 2006 | Alpine CDA-9856 CD Player
GPS Logo
61 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
