Question about Maytag SkyBox MBV1976A Beverage Dispenser
Need a new wire harness for dispensing buttons
The wire harness for the dispensing buttons is fried on my machine I have been trying for ten years to find a new wire harness , at first I called matag about issue and was told they don't make replacement wire harness and I have not been able to locate one ,is there any way to by pass this , I am tired of opening the door to get a beverage
  • 221 Answers
Http://refridgefreezers.com/skybox.html
Posted on May 08, 2014
5 Suggested Answers
chadschloss
  • 11 Answers
SOURCE: Skybox won't dispense anything
check the door where the cans come out. there is a sensor or the left side. if it is too far away from the door or if it's broken, it will do exactly what you said. i read somewhere that you can adjust the sensor closer to the door. i just bought one of the last one of these on the shelves 2 days ago and mine won't cool at all. stupid maytag..
Posted on Mar 08, 2007
  • 7 Answers
SOURCE: One button dispenses every other time it is pressed
Mine had what sounds like the same problem, and it was just a little flap next to the rotating drum that was stuck. It should be flat normally. Grab a flashlight and you'll see that there is a flap across the bin just before the drum, push it down gently so it lays flat.
Service manual:
http://servicematters.com/maytag_library/default.htm
Posted on Dec 28, 2007
SOURCE: Lights flash, but no beverage dispensed.
Check for jam or to see froze up
Posted on Aug 18, 2008
  • 3 Answers
SOURCE: skybox beverage dispenser. will dispense one can
I had the same problem as well. The dispenser thinks that the flap is jammed or that the beverage is stuck in the machine. There is a small magnetic sensor on the door near the flap and there should be a small metal piece on the flap itself. I fixed mine by (gently) bending the sensor closer to the flap. The sensor should not touch the metal piece, but if there is too much space the sensor always reads "open".
If that doesn't work, you can tinker around a bit to make sure that all of the connections are firm and there is not a bunch of frost caked on the circuit board. My skybox needs to be defrosted periodically, since all of the motors and the circuit board get frozen in a block of ice.
You can get to the circuit board by removing the racks as a single unit. Don't try to take the racks apart until you take them out of the fridge.
Posted on Jun 14, 2009
How do i replace the wheel sensor harness
if its it wire from the rear of wheel to frame get a new one --online auto stores junkyard those lines are not designed to be spliced the same with the main harness going to computer will need to replace the wiring
Sep 14, 2015 | Buick Rendezvous Cars & Trucks
Sorry we have no wiring harnesses or any parts for anything.
Mar 20, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Need to replace wiring harness on LG dryer DLE7177RM model. How can I connect the wires that extend inside behind drum?
Dryers are very easy to repair.
Video on how an electric dryer works: http://youtu.be/2xUKBtLkaeo
Video on how a gas dryer works: http://youtu.be/mcipN8bvpa0
Best regards ~
Mar 16, 2014 | LG DLE7177 Dryer
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
How do i get a blue spark
The issue is spark yes/no. The color is not really relevant. Any spark will usually fire the mixture.
Sep 13, 2012 | Ford 8N Tractor
Washer was just moved to a new house and doesn't work. It has F-13 code.
F13 Dispenser circuit error
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Jul 02, 2011 | Washing Machines
F30 was the code. Now we are just hearing strange clicking sounds from the top of the front loader washing machine. Any ideas/suggestions?
you need to check mechanical linkage from dispenser motor to the top of the dispenser. Then check wire harness connection to the CCU board. Check dispenser motor to see if it is getting power. After all that unplug unit for 30 mins,,,,,,, then try again
Jan 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Ice dispenser and water dispenser not working, also dispenser light not working ice and water dispenser won't work, light won't work
ouch!!!, heres what i wouldlook for, foirst off remove the lower kickplate, from ther youll see a wire harness leading from the bottom of the door leading to a multi plug right in the front of machine, unplug this. from there i would want to check the individual wires coming from the door. a natural pinch point is created from opening and closing the door and results in ripping of the wires.. youll need to cut the spider like harness covering they use to protect wires, im thinkn a few of those wires are definalty sheared..bad part is the only fix for this as perwhirlpool ios replace teh door( $500+) if this is the case, yhou cannot wire nut the connections( not enought room, you can solderthewires or i have had some sucesse in using what they call "**** connectors" to reattach.. just leave the harness unplugged till rectified( dont want to "short " anythin out
Mar 09, 2009 | KitchenAid KSCS25FKSS Side by Side...
Fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Jan 29, 2009 | Washing Machines
GE Profile Refrigerator Ice/Water dispenser not working
Had the same problem. Pressed button heard a click, saw zeroes flash, then nothing. After some online search I found and solved the problem. Corrosion and condensation on the connector plug attached to the wire at the bottom of the freezer door. Remove plastic grill, pull out wire from under box. You'll find a plastic connector and possibly wet or corroded wiring. CUT POWER TO FRIDGE OFF FIRST. I cut away the white plastic connector then stripped and tied the wires together with wire caps. Taped them up too. Note which wire goes to which first. Mine was blue to blue, black to black, and red to white. Problem solved.
Aug 02, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
51 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
