Question about Reliance 35,500 BTU 40 Gallon Mobile Home Gas Water Heater 640GOMT 300
Burner will not light
Water heater flashes a #4 code witch is a high temperature shutdown. What do I do?
Pilot light on. Gives a high temp shut down code. Need help.
I would check the thermostats, or possibly the temp sensor (if it has one). Sounds like the water heater is preventing the burner from turning on because it thinks the water temperature is too high (a safety feature to prevent the tank from blowing up, among others). If everything checks out, it may be the computer. The manual usually has explanations of the fault codes, otherwise I would try the manufacturer's website.
Feb 06, 2016 | Water Heaters
The pilot light on the water heater went out and the red light is blinking four times on the thermostat (Honeywell WV8860B1317). How do I get this to stop so that the pilot light can be relit?
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
Dec 08, 2014 | Water Water Heaters
Honeywell WV8840B1109 temp control valve on water heater. Status light @ 4 blinks between 3 seconds indicating "high temperature shutdown" even though lighting pilot with water cold. .
II have exactly the same problem: Honeywell WV8840B1109 temp
control valve on water heater. Pilot is on, but the burner won't
no matter how high I turn the temperature knob. Status light blink
4, which by the controller is "high temperature shutdown" and has
nothing to do with the problem. The real problem is that the
computer chip in the controller has gone bad. Problem is solved by
changing a new gas control valve/thermostat. The old Honeywell
control valve uses pure mechanical stuff and was very reliable,
almost never has a problem. I don't understand why they switch to
this new electrical one which use the tiny voltage generated by
the thermopile to run, easy to break, because of the electric
chips, and is more expensive. The only reason I can think of is
that they want to get more money from our pocket.
Nov 01, 2012 | Water Heaters
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
What can cause Hot/Cold spikes on an RTG74-XN
Crossover, low hot water flow, low water pressure, sediment in water lines or heater, heat exchanger needs to be de-limed, water filter needs to be cleaned, water heater temperature set too high, incoming water temperature too high or too low depending on model, MUD or PUD districts with pressure spikes, dirty faucet aerators, loose wires, bad sensor, faulty PD-board, bad venting, dirty burner and combustion parts, etc.
Crossover
http://waterheatertimer.org/Crossover.html
Clean water filter monthly, de-lime tankless yearly
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
No error code:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Overcoming fluctuating temperatures:
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
Resources:
Sep 20, 2011 | Rheem Paloma PTG-74XN / RTG-74XN Natural...
Is there a reset button for a 6G50NVH-FV-02 hot water heater
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
I have a Rheem 41VRP50N water heater. The water I am getting is luke warm on a good day. The burner fires up when I turn the thermostat to the highest temperature only. I drained the unit and flushed...
This condition can be caused by 4 different problems, or combination of these problems.
Good indicator would be to check temperature of water inside tank.
Put bucket under TP overflow tube and release water into bucket, then use cooking thermometer to gauge temperature. Stand back from scalding water that can shoot out of overflow.
If tank temperature is 120-130:
1) Crossover is suspect:
If tank temperature is low:
2) Bad gas control valve thermostat is suspect.
I believe Rheem 41VRP50N has Honeywell or White Rodgers electronic gas control valve.
Open following link to identify gas control thermostat and see typical error codes.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#Honeywell
Replacement gas valve can be purchased from Rheem.
3) Combustion parts and tubes need cleaning, and bleed gas line for air and water contaminants.
4) Water heater has sediment build-up coating burner transfer surface and covering thermostat.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Year of manufacture for Rheem water heater is 2nd two digits of serial number, so XX03.. would be 2003.
Add a comment and say what you did to solve problem.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
Jun 03, 2011 | Rheem Water Heaters
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Let the water heater do its job until it fails.
Oct 22, 2010 | Water Heaters
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Reliance 35,500 BTU 40 Gallon Mobile Home Gas Water Heater 640GOMT 300 Logo
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
