Question about Zenith Televison & Video
Nordmende tv screen too big
My screen is too big for the tv when I use a hdmi cable
marked
  • 6487 Answers
SOURCE: HDMI from laptop to DVI plug on Hitachi big screen TV
To fix it, just turn the set off, let it discharge for a few hours. Reach in and remove the socket from the back of the tube and reinsert a few times to break through the corrosion.
This is a sign of weakness in the manufacturer of the guns and the connecting sockets. The metal used in the pin connections inside the socket are corroding and when you remove the socket and reinsert it cuts through the corrosion and makes good
contact again.
If still not working contact the support for your television..
Hope that helps......
Posted on Jul 06, 2008
SOURCE: Cannot get my HDMI cable linked from my ps3 2 my hd tv
Try video settings on the playstation 3. Adjust it to reflect hdmi.
Posted on Feb 22, 2009
SOURCE: HDMI Connection
is the hdmi connected to the tv
Posted on May 29, 2010
sfender713
  • 397 Answers
SOURCE: I have my laptop hooked up to my Sony LCDTV (using
Go into your display driver, and make certain you have it set to have the internal LCD as your primary display. There should be an option to go ahead and have it either act as a second display just cloning what's on your screen or to have it extend. (select the option to clone)
Posted on Oct 03, 2010
  • 3799 Answers
SOURCE: want to hook-up my big screen tv to 7'' tablet bought cable ,hooked -up ,and put tv soursc e on hdmi . tv shows only words saying no signal ! why does'nt work????? thanks
Check the options on your tablet and select the video output to HDMI.
Posted on Feb 09, 2012
Connect desktop pc to my samsung big screen tv?
match the display outputs on the back of the computer to the inputs on the TV. ..use Appropriate cable and switch TV Input to that type
No matching input ??
Search amazon for converter cable
DVI to HDMI usually work
VGA to HDMI can be problematic and not work
Amazon com DVI to HDMI
Nov 15, 2016 | Samsung Televison & Video
Can I hook my tablet thru my wifi router or my cable box to stream internet TV on the big screen?
easiest way to stream to tv is with a cable. depending on the make of the tablet , you can buy hdmi micro cables to connect to tv. doing it wireless you will need a box plugged into the tv that has DNLA capability. both are available to buy.if you go for an android tv box they have that but also have XBMC which will allow you to watch any movie/tv programs/sports etc for free
Apr 28, 2015 | Tablets & eReaders
LG Tv M227WDL HDMI black screen
If the HDMI input is failing you will need to ring Customer Support or Get a New TV because if its not outputting then The HDMI may not get Prosecced (sorry about spelling) And make sure you have checked its the Correct port and that there is no Blue-Tac or dust in the port ( that ussually solves this) If all else fails Use a Hairdyer and give it a Big clean :D
Mar 14, 2014 | Televison & Video
I played my xbox 360 on a hd tv, then i switched to a regular tv and the picture wont work. What should i do?
If you are using the video cable (multi-colored jacks on one end, big trapezoid on the other) with the switch on it, make sure the switch is on tv and not hdmi. If you are using the hdmi cable (small trapezoid connection on both ends) then you need to find the video cable. You should also check and make sure that your screen settings are not for HD.
Go to:
System settings
---Console Settings
-------Display
----------HDTV settings
If the HDTV settings option is available then you have the hdmi cable attached or the switch is flipped on the video cable causing the 360 to think you're transmitting to an HDTV.
Hope this helps you.
Dec 17, 2010 | Microsoft Xbox 360 Console
Everytime I use hdmi the colours are mostly green
I have a panasonic th42pa 60a SD plasma and I get the same problem WHEN USING CERTAIN HDMI cables. I had a connexa brand with my samsung stb that i got with the TV and I had no problems., but i had to replace that because one of the ends "frayed" when it was accidently yanked out of the tv socket. A high quality monster cable did the same green screen you describe. The cheapest "Crest" from Big W that did HDMI standard 1b worked fine, but a Rank Arena from Target did not. So buy the cheapest HDMI 1b cable you can, the picture quality and sound is the same as the more expensive stuff. BTW I tried a HDMI 3 way splitter as well and it did the same green screen thing, but it worked on a later model panasonic plasma. I think it is Pana's poor HDMI implementation.
Dec 05, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
HDMI Connection
Apr 09, 2008 | Sony STR-DG510 Receiver
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Televison & Video Logo
12 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
