Question about LG Refrigerators
Dios R-D311PGLW my fridge sarts n shuts within five seconds..cant understand the problem..
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Keyless entery keypad how to reset
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the owner literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit mst be entered within five seconds of the previous button press.
Do you know the original five-digit code ? You need the original to reset with a new one .
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it overwrites the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system now responds only to the factory set code.
If you do not know the code ,it is located on the vehicle security module located under the dash some where or in the trunk . Sorry I can't be more specific ,my service info doesn't show sable .
Feb 17, 2016 | 2003 Mercury Sable
My acer aspire 1 725 wont load due to errorcode 0x00000f and cant get into bios to change boot options how do i fix this problem
Shut down your computer completely. Once it has been turned off, press the power button to the "On" position to restart the system. Within the first 10 seconds, press down and hold the F2 button for about three seconds and then release it. Within five to 10 seconds after pressing and holding this button, you should see the BIOS setup screen on the monitor.
Dec 30, 2013 | Acer Computers & Internet
Keypad instructions for entry - need instructions to change combination
Mar 06, 2011 | 2003 Mercury Mountaineer
How to reset code on door
Erasing personal code1. Enter the factory-set code.
2. Press 1/2 within five seconds of
step 1.
3. Press the 7/8 and 9/0 controls at
step 2.
The system will now only respond
to the factory-set code.
Programming your own personal entry code1. Enter the factory-set code (keypad will illuminate when pressed).
2. Press the 1/2 control within five
seconds of step 1.
3. Enter your personal 5 digit code.
Enter each digit within five seconds
of the previous one.
Your personal code does not replace the permanent code that the
dealership gave you. You can use either code to unlock your vehicle. If a
second personal code is entered, the module will erase the first personal
code in favor of the new code.
Oct 08, 2010 | 2001 Ford Explorer Sport
Please, give me step-by-step information on how to reset oil service light in 1999 Chevrolet Venture
Turn the key to the on position and press the gas peddle to the floor 3 times within 5 seconds then wait 10seconds this will reset the oil service light .P.S THIS ALL HAS TO BE DONE WITHIN FIVE SECONDS OF TURNING ON THE KEY AND HAVE THE DOORS SHUT :) THEN START THE VAN
Aug 09, 2009 | 1999 Chevrolet Venture
I need to know how to change auto door lock code on my mercury mountaineer
i dont know if this will help you but to change the auto lock codes on a 94 mercury sablethat is set into your remote keyless entry system at the factory.you can program your own personal code to unlock the vehicle. this code does not replace the prminant code that is programmed into your system.
to program your own code 1) select five digits for your personal code. 2) enter the code the dealership gave you. 3) within five seconds, press 1/2. 4) within five seconds of pressing 1/2, enter your personal code, pressing each digit within five seconds of the previous digit.
the keyless system registers this second code. to open your vehicle, you can now use either code. the module only remembers only one personal code at a time. entering a second personal code will erase the first personal code, replacing it withe new second one.
to erase your personal code 1. enter the original code. 2. press1/2 within five seconds of step 1. 3. wait six seconds
the keless entry system auto erased your personal code and will only respond to the permenent one. i hope this helps
Jul 24, 2009 | 1994 Mercury Sable
HOW TO OPEN THE DOOR USING THE NUMBER PAD ON THE DOOR
this from the owners manual
To program your own code:
1. Enter factory set code (keypad will illuminate when pressed).
2. Press 1/2 control within five
seconds of step 1.
of previous one.
Do not set a code that includes five
of the same number or presents
them in sequential order. Thieves
can easily figure out these types of codes.
second personal code is entered, the module will erase it in favor of the
new code.
If you wish to erase your personal code, use the following instructions:
1. Enter factory set code.
1 2 3 4 5 6 7 8 9 0
Controls and features
90
seconds of step one.
3. Press 7/8 control and 9/0 control
of step 2.
Unlocking the doors with the keyless entry system
To unlock the driver door, enter either the factory set code or the
personal code (each digit must be pressed within five seconds of the
prior digit). The interior lamps will also illuminate.
To unlock all doors, enter the factory set code or personal code (driver
door unlocks) and press the 3/4 control within five seconds.
Locking the doors with the keyless entry system
It is not necessary to enter the factory or personal code prior to locking
all doors. To lock the doors:
² Press the 7/8 control and the 9/0 control at the same time.
Activating/deactivating
May 19, 2009 | 2000 Ford Expedition
Not cooling properly
probably better off getting a new fridge. replacement could cost £150-250 depending on the engineer replacing it.
Mar 16, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Refrigerators Logo
12 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
