Question about Cameras
Cell phone battery loses charge as soon as i stop charging it
I just bought a cell phone, prepaid. Verizon LG Optimus. It WILL NOT HOLD A CHARGE. I called Verizon, they told me to call LG, the maker of the phone. I explained to them both, that MY CELL WILL NOT HOLD A CHARGE. That as soon as I unplug the charger, the battery starts going.......The maker, LG told me I have to take it back to the store I bought it at. They will NOT TAKE IT BACK. PLEASE, HELP!!!!!!!!!!! TY
  • Cameras Master
  • 5,412 Answers
Surely you have a right to a refund or exchange if it is faulty. Check with your local Trading Standards or Consumer Protection. Tell the shop you are doing this, they might change their ideas.
Posted on Jul 27, 2017
jackboy
  • 2985 Answers
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Posted on Jun 11, 2007
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
SOURCE: not able to charge battery
This happened to me also. In the manual it says the flashing light means that the battery/charger needs to be cleaned, or if that doesn't work, it is dead. My husband called customer service and they actually sent us a new battery which we recieved within a few days. The number is 1 800 706 2534.
Posted on Feb 03, 2008
Buschchris1
  • 474 Answers
SOURCE: My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Posted on Mar 25, 2008
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Posted on Sep 26, 2008
Connect to my computer
The lead that you charge with that has the USB on the end.
All the information, manuals, help and contact is here.
http://www.lg.com/us/cell-phones/lg-VS415PP-optimus-zone-2
Feb 03, 2016 | LG VS415PP Optimus Zone 2 Prepaid...
My lg optimus won't turn on our charge. Not even when I installed a new battery. What's wrong?
The Optimus S cannot be charged without the phone coming on. In order to restore that battery to where it can be charged within the phone, it needs to be plugged into an external battery charger. Once it is "topped up" to a nominal charge, the standard charger will be able to charge the battery.
A relatively cheap wall wart charger can fix this issue
May 28, 2015 | LG Cell Phones
How can I fix my LG-verizon optimus phone it will not charge when I plug it in to charger it won't do anything
Try removing the battery for a couple of minutes. Replace the battery and try again.
Worked for me when my Samsung phone failed to charge.
May 18, 2015 | Cell Phones
My battery runs out fast
get a new battery as it appears that the battery has developed a memory and will not charge past a set level
Apr 14, 2015 | LG Metro PCS Optimus L70 Prepaid...
What do I do if my phone keeps shutting off when its fully charged but when I try to take out the battery and put it back in it just starts blinking like crazy?
Your battery is dead. You can simply buy another of the same battery. Rechargable batteries do lose their charge for good after a certain amount of time.
Sep 12, 2014 | LG Optimus V 3G Prepaid Smartphone w/...
Why won't my phone charge up
it is yr port take it in get it looked at.
Jul 15, 2013 | Virgin Mobile - Lg Optimus Elite Mobile...
How long should i charge a new optimus black
The optimus black phone should take 2-3 hours to fully charge. When you get a new phone, however, it is generally a good idea to let the battery completely die before you start charging it.
Over time, batteries hold less and less charge. Supposedly, by allowing the battery to completely die before charging it the first time, you improve the longevity of the battery.
Feb 10, 2013 | LG P970 Optimus Titanium Black Android 2.2...
My lg lotus won't charge
you need a new battery..the phone bypasses the battery when its charging and in use..but your battery doesnt hold a charge
May 16, 2009 | LG Lotus Cell Phone
Wont charge
your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
Apr 18, 2009 | Verizon Communications LG enV Cell Phone -...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
