Question about iPhone Apps
I have a nddn w56 76031 car deck and i was messing around with the setting and i took off the grid that appears when u are reversing. how can i enable it or get it to show again. very frustrating. a
Reverse grid
  • 272 Answers
SOURCE: 96 escort manual 5 speed stuck in reverse
Is the stick moving? or is it 'stuck' in the reverse position as well? There are adjustments but it seems more likely that your 'stick' has come unstuck from the gear levers that actually put the gears in the right spot. Have someone look at the transmission while you move the stick to see if the levers are moving and put your response here.
Posted on May 08, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 437 Answers
SOURCE: My BMW 328ci won't go in reverse. I took it to the
flush it again.
Posted on Dec 02, 2009
SOURCE: no reverse gear
This question should be deleted. Aside from the obvious illiteration, there is nothing in the known universe that could be stuck in an oil filter that could cause the transmission to fail, nor could the oil pressure. What most likely happened is someone did a neutral drop and blew a solenoid in the transmission. Rebuild/replace transmission, or drive without it.
Posted on Jan 22, 2010
  • 12 Answers
SOURCE: NDDN-W56 car DVD player shows "PLease insert
check there...
http://www.gps-guru.com
Posted on Aug 07, 2011
Radio cuts out
Did the xplod deck work correctly before you installed it? When it cuts out does it loose all its memory and setting and go back to factory defaults? It is possible that the deck is faulty.
Nov 15, 2013 | Dodge Neon Cars & Trucks
NDDN-W56 Unlocker software
hi Aliadnans
need a help please, for ''insert correct map disc'' NDDN W56 device.
my email: distingue8@yahoo.fr
Jun 21, 2012 | Car Audio & Video
NDDN-W56 plays audio but no video
The laser reader has failed or the laser reader logic circuit has failed, you will need to pull the deck out and sent it in for repair.
Feb 15, 2012 | Cars & Trucks
My toyota vitzs 2007 modal came with NDDN w56 multi av station i fixed a rear view camera by connect the vedio yellow cable and power to the reverse gear light but when put reverse gear no no display .any...
you don't need any settings actually it works with a three wire camera because the camera operates on 7volts and is powdered by the system, no need to connect it with the reverse switch, its already wired to the system, just connect the camera and will work.
May 12, 2011 | Car Audio & Video
No installation softwere for gps dvd player NDDN W56 in english
Software for NDDN-W56 is only available in Japanese if its in Japanese by default.
if you want solution for ERROR" Please insert Correct Map CD" then post your email address here I will send you NDDN-W56 software Torrent for downloading along with instructions. 100% working on NDDN-W56
Mar 24, 2010 | Panasonic Car Audio & Video
Hi, i have a vitz and they had installed a nddn w56. At the beginning it was good but in a suddenly The Player is show on the display screen to insert the correct "please insert the correct map disc" . It...
you need to re install the software disk cause most probably ur battery was disconnected at some point and it went back to default. PS I'm also maltese siehbi
Feb 05, 2010 | Car Audio & Video
No pic, just a black screen w/white grid on it. How do I get picture back on it.
Sounds like they enabled some test mode of the TV. Can you activate the menu using the remote control and see if you can navigate to disable that? How about if you just unplug it from the wall for 60 seconds and plug back in and maybe it will reset.
Apr 16, 2009 | Televison & Video
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
Screen flashing
1 Press SOURCE and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
Language select appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
Switching the reverse mode
If you do not perform an operation within
about 30 seconds, screen indications start to
reverse, and then continue reversing every 10
seconds.
1 Use MULTI-CONTROL to select
Reverse mode.
2 Press MULTI-CONTROL to turn the reverse
mode on.
# To turn the reverse mode off, press
MULTI-CONTROL again.
Note
You can also turn on or off reverse mode by pressing
BAND while this unit is turned off.
Oct 26, 2008 | Pioneer DEH-P690UB CD Player
iPhone Apps Logo
83 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
