Question about Sharp KB6524P Microwave Oven
NEED TO CHANGE FUSE ON MICROWAVE kb-6524p - Sharp KB6524P Microwave Oven
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
Sharp KB-6524PS no power
There probably is a fuse inside but replacement depends upon your degree of comfort with disassembly while maintaining awareness of the dangerous voltages lurking inside.
Jan 14, 2014 | Sharp Insight Pro Series KB-6524PS 24""...
Sharp KB-5121K won't heat -- everything else works.
It may be the fuse supplying the magnetron, or the magnetron itself which has failed. Another suspect is the high voltage capacitor in this circuit.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
Aug 31, 2013 | Sharp R-1480 Microwave Oven
Sharp microwave kb-6002ls making buzzing noise
Someone would have to open the unit to "hear" where it is coming from, possible fan issue or even the power unit inside.
Dec 03, 2012 | Sharp KB-6002LS 1000 Watts Convection /...
Blowes 20 amp fuse replaced it blue agane
If the microwave oven is 7 years old or less, the magnetron is shorted or the inverter board is.
Jul 01, 2012 | Sharp KB-6015KS Stainless Steel 1000 Watts...
Is it possible to blow a fuse on a micro oven? And where would I change it?
There is a fuse found behind the upper grill, it is likely a 20amp fuse.
If the fuse has blown, it is likely that the door safety switches need to be replaced.
Change the fuse (unplug the micro first) and continue using. If the fuse blows again, have it serviced by a qualified service person.
Dec 30, 2010 | Goldstar MV-1502 Microwave Oven
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
Sharp KB6524P Microwave Oven Logo
59 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
