Question about Fellowes C-320 Shredder
Knocking sound while shredding
A knocking sound while shredding high volumes
Royal shredder high pitched motor sound
stripped a gear
junk it and get a new one
Jun 10, 2017 | Royal Office Equipment & Supplies
How do I fix my model tv No picture but knocking sound?
The knocking sound is the high voltage trying to fire. That would tell me that the high voltage splitter has failed or one of the 3 picture tubes (not lamps) has failed. Most likely too expensive to repair a TV that old.
Sep 12, 2015 | Sony Televison & Video
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
How do I fix the knocking sound for my t.v.? It makes a loud knocking sound when I turn it on and continues until I turn it off.
Knocking? it sounds like you have a bad connection somewhere in the tv and it may cause a fire. i wouldnt turn it on again until you get it to a repair shop.
Oct 17, 2013 | Haier HL37S 37 in. LCD HDTV
Hi my 1986 golf MK1 makes a knocking noise in the front which sounds like its on the body while driving, please help.
Those bushes would have to be shredded or missing for it to make a knocking sound. And should be a visible problem, I would think.
Apr 16, 2012 | Cars & Trucks
Hello,i have a echo es-1000 shred n vac.It will run full out for a minute and then wants to quit.
sounds like a minor adjustment on the high side which is the micture screw to the filter side when it starts to die put the choke on partiallyit should recover breifly which will tell you its a adjustment on the high side
Nov 02, 2009 | ECHO, Inc. Shred n Vac
The engine knocks at higher rpm, only at high rpms
First no matter what check the oil level and then if it's a high rev tapping you need to allow the oil to flow through the engine block to try to coat and settle your valves.
But if it's really " knocking " sounds like your lifters and rocker arms are allowing your piston rods to clatter and that needs to be looked into fast.
Jul 27, 2009 | 1992 Dodge Dakota
Whirlpool Duet GHW9100 Drum Knocking/Plastic Tub Shredding
This is joyce
The bearings is gone in the drum, causing the drum to rub and run the wrong way one the pully, yes it is very exspensive, I have the newer model.
let me know if I can help
thanks
joyce
Feb 13, 2009 | Washing Machines
Knocking sound
my solution to you is ask some one to check out your cvc joints cause once cvc joints go bad it starts to sound like your engines knocking but its the joints that are right next to the tire on the axel get under your car and look right behind the tire if there is a rubber here's a image of what the rubber on the axel should look like if its ripped or torn or even shredded thats your problem
ts?t=15705397540890858194&pid=23104&ppid=18
Feb 03, 2009 | 2002 Mazda 626
My Royal shredder is knocking
The gears may have come out of whack. With the power off you can try opening the mechanism to reset it. -Vish
Oct 04, 2007 | Royal 160MX Shredder
Fellowes C-320  Shredder Logo
41 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
