Question about Studiologic Sledge Synthesizer - OPEN BOX
Reset factory - Studiologic Sledge Synthesizer - OPEN BOX
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
Contact boss
BOSS ME70 Factory Reset.
Just do this:
Jun 11, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Factory reset Behringer FBQ2496
After my FBQ 2496 began to go "wild", it finally went blank with a ticking sound. I tried pressing and holding the "Reset" and "Bypass" buttons, simultaneously during power on. It worked after 3 or 4 tries.
Feb 24, 2014 | Behringer USA FBQ2496 Ultra Fast 24 Bit 96...
HOW TO RESET BOSS GT3 GUITAR PROCESSOR TO FACTORY SETTIGS
Turn off and restart while holding down "mod" and "sfx", then answer a choice or two about starting point and ending point, just move curser to the beginning.
Mar 09, 2013 | Music
How to reset the pedal 25 ME? thank you.
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
Feb 15, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
Hw to cancelvirus in pa 800?
Do a factory reset. Look in your book or search for: "Factory reset pa 800" with google.
Sep 18, 2009 | Korg Pa800 Synthesizer
Studiologic Sledge Synthesizer - OPEN BOX Logo
111 people viewed this question
Top Studiologic Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Studiologic Music Expert? Answer questions, earn points and help others
