Question about Belling DB2 Dual Fuel (Electric and Gas) Kitchen Range
Ignitors click when both overns are on - Belling DB2 Dual Fuel (Electric and Gas) Kitchen Range
Kenmore 790.70603013 oven and broiler do not heat up, no gas smell and no ignitor glow. Top burners work and overn light is functional.
You will need to replace the igniter in the oven. Here is that part to order.
All parts come with a 365 day, any part, any reason return policy.
Oct 24, 2013 | Kenmore Kitchen Ranges
Ignitor keeps clicking on burner
A creda microwave oven doesn't have an ignitor or burner, so I assume you are talking about either a BBQ grill or gas range.
A suggestion: Clean the ignitor tip with a CLEAN and DRY green scouring pad; check that you have gas coming out of the burner.
If you have gas at the burner and the ignitor is clicking (sparking) then it is usually an ignitor alignment problem where the ignitor got bumped out of position.
Jun 06, 2011 | Creda Microwave Ovens
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
How do I remove the overn door on a Garland range
please if you can, provide a model#, or more information, I have never had to remove the door in order to get the pilot, wanted to, but not necessary :)
Dec 21, 2008 | Garland H283 Gas Kitchen Range
Overn won't lite
change the oven ignitor, that's the electric pilot nest to the oven burner.
Dec 08, 2008 | Whirlpool GS460 Gas Kitchen Range
Overn will not work properly
sounds like you have a bad oven ignitor, very common problem with alkl gas ranges, easily repaired by you a few screws and a wire harness part number 12400035
Apr 05, 2008 | Ovens
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Belling DB2 Dual Fuel (Electric and Gas) Kitchen Range Logo
21 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Mike Carew
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
