Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
Intex filter model 633 with no instruction manual on how to set i
I have a model 633 intex pool filter with no instruction manual. I am not sure how to set it up. Can you help me.
You can go to the website for Intex products and once you get to product section you can find and download a pdf manual
Posted on Aug 05, 2009
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
I need a instructions manual for hooking up the pump to my intex above grownd pool
Go to www.intexcorp.com. On the home page, you'll have to chose your location/country. From there, click on " Need replacement parts or Accessories for Intex Products", under Consumer Info heading. Near bottom of page on right side. From there, click on " Instructional set videos and manuals, on right side of screen. Then click " Product set up manuals". From there, chose the type of filter you have and the instruction manual will open. Or you can click on the product set up video to nsee how it's set up!
Jun 05, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Intex 633 lost suction
I have seen a common problem when customers change / clean their filter is that put the DRY clean filter in the skimmer box or filter holder and sometimes it can cause an "air lock"
Just take your garden hose put in the intake outlet of your pool and turn that baby on....If you start seeing air bubbles on the discharge end of the line most likely that was your trouble.
If the problem still persist then at that time look into pump repair / replacement.
Good Luck!
Jul 13, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Which tube takes water from pool to pump and which tube puts water back in on the model 633
The outlet from the skimmer goes to the pump inlet (center) the pump outlet goes to the filter inlet. The filter inlet goes to the return to the pool.
Jul 03, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
Water flow seems to restricted and the hose caves in
I FOUND ON MY INTEX POOL WHEN HAVING THE SAME TROUBLE IT HAD BLOCKAGE BETWEEN THE 1 1/4 HOSE ADAPTER ON THE INLET SIDE OF THE CONNECTION SUPPLYING THE PUMP AND THE BLUE FILTER SCREEN BEFORE THE OUTLET VALVE. MIGHT BE WORTH CHECKING THERE AS THE STRAINER BASKET WILL NOT CATCH ALL THE FINE DEBRIS. TAKE YOUR OUTLET HOSE OFF AND OPEN THE VALVE AND SEE IF IT IS RETRICTED.
Jul 01, 2010 | Intex Plunger Valve & Straniner Basket set...
Need instruction manual to set up my pump for intex easy set up
The correct website is intexstore.com
on the right side, about half way down the page there is a blue box that says instructional set up video and manuals. You then click on pumps and on your model, and you can open it there.
Jul 13, 2009 | Intex Pool & Spa
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
816 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
