Question about Dell Inspiron Computers & Internet
PC STARTS UP BUT NO MONITOR
MONITOR IS ON BUT NO PICTURE
  • 70 Answers
Try to change your monitor.
Posted on Apr 05, 2015
    Top Expert:
  • Dell Master
  • 4,971 Answers
Check graphics card or the vga cable
HD3870x2 dont run on my P5kpl-AM
Are you sure your monitor is OK ? I had similar issue, but monitor was fault. It showed picture then went black.
Try in dark, when it goes off, with the LAMP (LED or something) and point it to your monitor, if you see picture, I believe your monitor lights are out ..
I would suggest to try with another monitor to rule out monitor, after that you should check graphic card, try runing some benchmark tests, .. usually issues are connected with temperatures or bad memory.
Oct 14, 2013 | ASUS Computers & Internet
My viewsonic vx924(vs10162) start very good when i turn on my pc then after 2 or 3 seconds goes white but i turn it off and on again and it works just fine i try it with other pc and does the same what can...
The picture board on your monitor is bad, since the power led or button is on and all connection are correct and goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 04, 2010 | ViewSonic VX922 19" Monitor Flat Panel
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
Asus p5gd-1vm motherboard no picture on display
in that case start system in safe mode after start safe mode please delet vga drive and then reinstalled it then after its worked.
May 11, 2010 | ASUS P5GD1-VM Motherboard
We can not seem to get it to recognise our new hp pc.
Start the New PC in safe mode. In safe mode the PC will have low resolution, and must be seen in any monitor.
If you cannot see safe mode picture, then check the cables. If you can see picture in safe mode, go to Personalize in control panel, find printer settings and lower resolution and change screen size.
Oct 14, 2009 | Dell E176FP 17" LCD Monitor
I have a pavilion a6042n. I am getting no picture
Do you ever see a picture on the monitor when you start the PC? If not then try hooking up the monitor to another PC or laptop to see if it works. If it does the same thing then your monitor is bad and you will need to replace it. If it does work try another monitor on the PC the monitor doesn't work on. If the 2nd monitor doesn't work then you have a video issue.
If you have a video issue you will have to replace the video card unless you have onboard memory. If you are not sure which one you have take it to your local PC store to have the check the video. If they tell you that you have onboard video or intergrated video then it is probably going to be around $200+ to repair it. You may want to buy a new PC and have them transfer your data.
Sep 13, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
Blank Screen..Will not power off
The flash light test only works with lcd monitor as they have back lights. Double check the connections again, also, if you can borrow a monitor try it on your pc, it may be your graphics driver needs to be uninstalled and re-installed, but you will need a monitor to see.
Dec 13, 2006 | Proview PS 776 Monitor
Computers & Internet Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
