Question about LG DS420 DLP Projector
The projector is displaying a green color
Whatever is displayed using the projector is displayed in like a green color
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Could be the color wheel or over-heating. Make sure the vents are all clear.
Posted on Jul 03, 2015
Sharp Notevision PG-C30XE problem with computer display
There are 3 different types of analog video signal ports on your projector; s-video, composite video, and RGB. Which one of the three are you using to connect your PC to?
The projector's resolution rate is XGA [1024 x 768]
If you are using a VGA cable designed and capable of handling 640 x 480 resolution; then it will not support XGAs 1024 x 768 signal. On the other hand, if the coaxial cable you are using is a multi band one that is capable of supporting VGA and XGA resolution signals, most likely the problem is not with the cable- although I have come across brand new cables that are defective.
Please let me know if this helps or else we'll try another approach :)
Nov 25, 2013 | Sharp Notevision PG-C30XE Multimedia...
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
My dell 1201 projectors displays only in yellow
you have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Mar 23, 2011 | Dell 1201MP Projector
Optoma EP757 displays green image when input connected. Initial splash screen displays fine. All colours are the way it should be but as soon as a video source is connected, it displays the image in...
I would suggest replacing the type of cable you are using. Changing the type of connection, such as S-Video or VGA or something other than what you are using, may resolve this issue as well. Because the splash screen comes up normal, this tells us that the issues lies not with the device but with whatever it is you are connecting it to. Comment back if this does not resolve the issue and we can move further.
Good Luck,
NOLA Tech
Jan 27, 2010 | Optoma EP757 DLP Projector
Yellow green display
you may have a bad cable. if it was an internal problem, the menu wouldn't be the correct color. you may also want to reset the settings to factory default, just to cover the resolution issue.
Jan 13, 2010 | InFocus LP70+ Multimedia Projector
Green Screen
Not bulb related, it is related to the i/o board on the back of the projector. Something is shorted or making poor connection
Apr 29, 2009 | Dell 3400MP Multimedia Projector
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
NEC LT35 color problem
If you're trying to project video, then the unit needs professional service. If you're trying to project from a computer, you may have a loose display cable, broken pins in one or both ends of the display cable, or broken conductors (wires) within the display cable. The computer sends its image information as a template of RED image components, GREEN image components and BLUE image components with the projector overlays to create the complete image with blended color values. (The computer also sends HORIZONTAL and VERTICAL synchronization signals, but those don'e affect the color content of the projected image.) That's why I'm suspicious of the display cable, conductors or pins.
Jul 02, 2008 | NEC LT35 Multimedia Projector
LCD projector has a 'shadow' in the green color
This is a Mainbord problem , the lcd would have shown blotches on your imagr rather than a shadow effect.
Apr 19, 2008 | Office Equipment & Supplies
LG DS420 DLP Projector Logo
156 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
