Question about GE Profile PDW8400J Built-in Dishwasher
Right side door hinge is disconnected. any ideas? It seems that the pin has dislodged from the door bracket, but the pin has a cap or flange on the end that is far bigger than the hole in the bracket. it is very confusing to figure how it came apart and how to reconnect it.
  • 4 more comments
  • keith_small Jun 14, 2009
    I have already removed the lower panel. the door was resting on it, so when I removed it the door on the right side fell to the floor. The spring is connected to the door bracket with a plastic connector.
    Yes, the photo of the "newer GE dw" showes the hinge bracket very clearly. the hinge pin is not evident in the photo, but at the location of the arrow head on the photo is where the pin is located. that is what has detatched from the fram of the machine.
    I could email you a photo if you like.
    Below are the responses from me to the last "expert". He insisted that the door spring is the issue. The spring is connected and fine, the problem is the pin of the hinge. Can you help?
    Yes, the photo of the "newer GE dw" shows the hinge bracket very clearly. the hinge pin is not evident in the photo, but at the location of the arrow head on the photo is where the pin is located. that is what has detatched from the fram of the machine.
  • keith_small Jun 15, 2009
    PART NO 809 WOULD APPEAR TO BE THE ISSUE. HOW DO I REPLACE IT?
    I sent you 3 photos, I hope you can explain how I can reattach or replace the pin. I would guess that I will need to pull the dw out of the cabinet area enough so that I can disconnect the spring and dissemble the hinge bracket in order to re-connect with the pin. Is this correct?
    I removed the screws at the top of the dw from the counter top, but can't seem to move the unit out. should I be looking for another anchor?
    Ok... I will send you a pic later today. What you say makes a lot of sense, however the left side has the pin connected to the hinge bracket similar to a rivet, and the right side has no indication of a relief or indent to accept the the hinge bracket to sit on. It has a hole that is smaller than the head of the pin. so, it looks as though it was permanently installed at the time the machine was assembled.
  • 11,896 Answers
There is usually a smaller pin that attaches fro door hinge and goes inside other pin that is attached to washer. The outside pin is attached by machine press.
Posted on Jun 15, 2009
  • 986 Answers
I have read the problem and I do agree the hinges are your issue, not the spring. The hinge has a large head on botyh sides? Sometimes the large end is the stop for the pin. Let me know.
Posted on Jun 14, 2009
  • Roger Campbell
    Roger Campbell Jun 14, 2009
    mail me a photo at rogrrabbit@aol.com
  • Roger Campbell
    Roger Campbell Jun 15, 2009
    Quote...I would guess that I will need to pull the dw out of the cabinet area enough so that I can disconnect the spring and dissemble the hinge bracket in order to re-connect with the pin. Is this correct? Qoute... Yes after looking at the pics you emailed me. The cap or end of the hinge is just the design, much like a tail gate of a truck the door will just sit over it and the cap will keep the door in place. So like you said pull out the DW diconnect the spring/ hinge bracket. Then just slip the door back on. to reconnect with the pin. The screws at the top of the DW that you removed from the counter top, that should be your only anchor point just get a firm grip and pull.
    Also send me a pic of the door where the hinge go to ensure what Iam saying is correct. Good Luck
    Brigadier General:
  • 8,619 Answers
Hi
You may have had a door spring break. There are several different door springs, but most, if not all dishwashers have 2 door springs. You will need to remove the lower access panels to get at the springs. They are fairly easy to get at and replace :-) This is a collection of some common springs used today, link is here.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jun 14, 2009
    Did you check the link that I attached in my solution as it will explain you everything.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    I believe the plastic link between the spring and hinge may have broken and you need to get that replaced.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    Please check this link for checking the hinge pin. Also see the exploded view of the whole door and its parts--
    GE Profile PDW8400J Dishwasher Door parts
    Check parts# 801, 800. Also see this link for your refrence--
    GE Profile PDW8400J Dishwasher Parts
    Thanks
    Rylee
How do i change the door so it opens from the right
Check the top and bottom of your fridge door at the furthest edge from the hinge. Do you see a plastic plug/insert, usually round that looks like they can be levered out with a thin blade? These cover holes that a hinge pin can be inserted into. At the hinge side (top and bottom in the same position as the aforementioned plug/insert) is where the hinge is attached to the door. If you remove the hinges from the fridge they should then come away from the door and you can swap them over to the other side and replace the plug/insert in the holes left where the hinge pins were originally fitted. The door should then be fitted to the other side of the fridge in holes similarly covered by a cap that you put in the holes left where the hinge was fixed.
I hope that makes sense, because I've just read it and confused myself I think.. ;)
Nov 20, 2015 | Refrigerators
When flipping the doors on a ge gts18icmbrww can the door brackets work on both sides?
Most of the time doors are reversible. The non hing sides usually have plastic caps over the screw holes, Just remove them and the hinges and re-install on the other side. Pay attention to any spacers you find between the door hings and pivot pins so they go back in where they were.
Mar 17, 2015 | GE Refrigerators
How do I change the door from left hand to right hand opening
on the top right hand side of the refrigerator you should see little screw cover caps,, also on the door and on the bottom of the door. remove these caps -- now remove the screws that hold the hinges for the door and just switch everything over to the other side. everything is a mirror image of the other side --- where there is a screw that holds the hinge on one side -- there will be a screw hole on the other side that is covered by a finish cap,,, same thing with the hinge pin hole. tighten everything up and use the finish caps to plug up the now exposed holes and there you go -- right hand opening door.
if you have any troubles -- just write me back here and I will do my best to walk you through it.
c...
Feb 03, 2011 | Kenmore 72912 / 72914 / 72919 Bottom...
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
How do i replace the bushing on the slider door
1. Remove sliding door trim panel , watershield, and access hole cover plates.
2. Unlatch pizza sliding door.
3. Remove latch actuator rod retainer from center door retainer hole.
4. Disconnect pizza rear door latch actuator rod from pizza remote control assembly by opening pizza clip.
5. Open pizza door sufficiently to gain access to pizza three bolts attaching pizza rear latch to pizza sliding door. Remove bolts.
6. Remove pizza sliding door rear latch with pizza remote control actuator rod attached to pizza latch, from pizza sliding door.-------------
First you need to get the right tools for the job and the right parts to fix the problem.There is a hinge pin in both the upper and lower hinges and four brass bushings and there is two different size bushings in each hinge and also two hinge pin retaining washers.as for the tools you need a spring compressor,jack,hammer,punch. First open the door all the way,put jack under door,I like to use a 2by4 board on top of the jack to help spread the wieght of the door out a little,next if the door has a wireing harness in the jamp loosen the rubber insulation form both the door and the body this gives a couble of inches of slack in the wireing.Next use the spring compressor to remove the spring,then use the punch and hammer to drive out the pins.it is very hard to get them to move an first but gets easyer as they start to move.I would recomend having a helper to hold the door upright as it will fall when the pin is removed from the hinge.Onece the pins are out move the door and jack away from the body to gain more axcess room the replace the bushings,two in the door side and two in the body side,then slide door and jack back and align hinge holes and install new pins. I allways grease the bushing and pins before installing.Drive the new pins all the way flush with the hinge and install the retainers.Reinstall the spring and reattach the wireing insulation. ------- Open the door so it is directly above the bench. Observe how all the fasteners, be they bolts or pins with bushings, are aligned. Generally, the bolts and pins point toward the center of the hinge from the top or bottom, The bolts and bushings are on the body-side bracket for the upper bracket and the door bracket for the lower one. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Apr 01, 2010 | Mercury Villager Cars & Trucks
I have a frigidaire refrigerator with top freezer. model frt21nfrd2. About 12 years old. With a light inside you can see light in the top right of the refrigerator door. Seems to seal good every where...
remove freezer door. now remove hinge on top of bottom door. lift bottom door off. now place a washer on bottom hinge and re install everything. this should solve your problem.
Feb 01, 2010 | Refrigerators
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Ksrg25fkss kitchenaid refrig door needs height adjusted up
Have you looked at the mounting bracket for the lower hinge to see if it can be adjusted up. If not and there is as mush as 1/4 to 1/2" adjustment i suggest that you get a spacer with the inside diameter the same as the hinge pin or a tiny bit bigger and cut it to the size you need , then support the door up to a point that the bottom pin is not bound, remove the lower bracket and hinge pin, put the sleeve you cut on the hinge pin and reinstall the bracket.
Jul 28, 2009 | Refrigerators
Fuel door release will not open
  • Remove fuel tank filler cap.
  • Push back release rod - 9 - by operating remote control unlock and remove bolt - 2 -.
  • Remove rubber part - 8 - from tank filler flange and swivel out tank flap unit - 1 - from side panel - 7 -.Assembly piece - 4 - and actuator - 6 - is installed.
    • Install tank flap unit - 1 - (rubber part rolled up) with hinge side first.
    • Bolt tank flap unit - 1 - and assembly piece - 4 - with bolt - 2 -.
    Tightening torques: Bolts - 2 - 1.5 Nm
    • Remove side luggage compartment trim.
    • Disconnect harness connector at actuator - 6 -.
    • Remove actuator - 6 - using special tool Socket wrench T 10010 from angled mounting bracket.
    • Remove actuator - 6 - together with release rod - 9 - from seal - 5 - and assembly piece - 4 -.
    Installing
    Installation is reverse of removal.
    Tightening torques: Bolts for actuator - 6 - 1.5 Nm .
  • May 27, 2009 | 2001 Volkswagen Passat
    Frigidaire follow up side by side door noise.......
    ok these hindges are confusing but the hinges that came with it are not in right place
    example top bottom
    bottom top switch them they should match door geometer of made holes
    one bracket on bottom door fits on bottom bracket
    the top bracket goes on top of the door to hold the door in
    May 17, 2008 | Frigidaire FRS3R5EMB Side by Side...
    GE Profile PDW8400J Built-in Dishwasher Logo
    163 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
