Question about Viking VGBQ410-3RT Grill
Ignition "clickers" and interior lights all not working. Outlet has power but not juice getting to the electronic components.
Had my electrician come out and the outlet has 120 volts so something is wrong with the unit. It has tripped the GFI a few times over the years, but that was remedied by resetting it.
4 Suggested Answers
  • 1462 Answers
SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Posted on Jun 19, 2007
  • 20 Answers
SOURCE: My 48" Viking Range top trips the GFI
One leg of the power is "dead shorted" to ground. Use a Multimeter and start looking/testing to determine which component is bad.
Posted on Sep 01, 2009
heatman101
  • 43501 Answers
SOURCE: unit has no power.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 15, 2011
Plugged camper into 120 volt everything works electrically except ceiling lights dont work
* Check 12 volt DC system (may be camper battery or car battery, though most only use the camper battery.)
* Camper may be using 12 volt DC lights so it can be turned on while your on the road or not hooked up to an 120 VAC or 240 VAC outlet.
* If you are using 120 VAC lights then check the neutral line (note; HIGH voltage here. Get help from an electrician or at least the RV park handyman.) The problem may be at the outlet (the RV site's problem) or more likely in your plug or cable (the big cord) as it does get abused, run over, kinked, etc. Need to have it checked by an electrician.
* Check the light bulbs; is it seated properly? Replace if burnt out. Have electrician test if there is power at the socket.
* Final; Be safe and have a qualified electrician service your camper.
Aloha, ukeboy57
May 11, 2018 | Electrical Supplies
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
Range rider bugy with a kawasaki fc290v electronic ignition with a fully charged battery i turn the key and get nothing any ideas ?
I would say you should check to make sure you are getting juice to the starter when you are trying to start it. This can be done with a simple voltmeter or 12v light tester. If you are getting juice, then the issue seems to be a bad starter. If you are getting juice the it could be the solenoid, ignition switch or a simple loose connection. I will be more than happy to help you get this up and running. First start by testing to make sure you have juice going to the ignition switch and the starter when you turn the key.
Jun 25, 2012 | Cars & Trucks
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
We had a thunderstorm with lightening in the area. The LG was plugged in at the time, but NOT turned on. after the storm, the tv will not turn on. the little green button turns from red to green...
As an electrician, when someone loses more than 1 item of electronics in a day, its almost
always traceable to a nearby lightning strike, accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
The converter box may be replaced by DirecTV, you'd have to contact their customer
service at http://www.directv.com/DTVAPP/content/customerservice
If desperate, you could try replacing the entire TV power supply as a module, but even this provides
Aug 17, 2011 | LG Televison & Video
Both of my tv's died yesterday. My apex wont turn on anymore an the panasonic has no picture. Whats wrong.
As an electrician, when someone loses more then 1 item of electronics in 1 day, its almost
always traceable to a nearby lightning strike, accompanied by a lack of surge protection for
If desperate, you could try replacing the entire power supply as a module, but even this provides
Aug 15, 2011 | RCA F36450 36" TV
My battery keeps draining after 2-3 days, I've had the alternator checked, in which it is working properly. What could drain a battery after that short time span. the battery has been replaced twice
For starters, make sure that you don't leave any electrical components on. If that is not the issue then check the cars wiring. Have an electrician check it for you. My hunch is that there is some wiring somewhere that is not properly grounded and/or there is a short circuit somewhere. These two things will lead to battery drain especially since removing the key from the ignition does not turn all the electrical components off. (ex. the headlights, horn, tail lights, brake lights, interior light may be turned on even without the key.)
Dec 17, 2010 | 1996 Nissan Sentra
Juicier will not work at all
Try the juicer on another circuit to see if the breaker failed altogether on the circuit you were using. It's possible that the machine is drawing more power than it should and may need to be checked by an appliance service dealer. An electrician can also check the power draw at the breaker to see if it is being overloaded. If the machine itself is defective, it should receive professional service. Good luck!
May 07, 2010 | Champion G5NG853S Household Juice...
No power or very little juice to the car replaced battery no help
Yes, you have a bad starter solenoid, underneath the car wiggle the red feed to the starter wile a friend has the key in the start position, it should click or start the car.
Feb 20, 2009 | 1999 Lincoln Town Car
Cold weather Car won't start, but fan under hood does
Because ur lights ar eon when u turn the ignition key doesn't necessarily mean the battery has juice. It probably does to do those things, but it probably doesn't have the cranking amps to send to the starter so that it can turn over the engine. But if the battery is good, it means that ur starter is not working properly, because u said that the engine isn't turning ove. Try tapping the starter a bit and c wut happens. Sometimes it works. If unsure, consult with an auto-electrician. This is definelty an elcetrical probelm
Jan 29, 2009 | 1986 Toyota Celica
Viking VGBQ410-3RT Grill Logo
41 people viewed this question
Top Viking Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Mike Hollander
Mike Hollander
Level 1 Expert
Are you a Viking Grilling Expert? Answer questions, earn points and help others
