Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Kicker substation setting
Clipping my car radio
I have a LED TV that was hit with a power surge caused by lightning.
Could be your household insurance would cover the damage.
Unless the lightning strike was very local to you, on your side of the local substation, the responsibility for the cost of repair or replacement could be the power company's.
Surges from lightning strikes aren't supposed to get past the electrical substation.
Old-fashioned valve tvs and radios sometimes survived huge surges on the powerline and even minor lightning strikes to the antenna but solid state semi-conductors and micro chips aren't very tolerant to overloads of any sort. These days a tv is not longer a tv in the conventional sense but like cars and radios should be considered as just another computer that is full of CMOS chips which are extremely sensitive to overloads and static discharges. Even the screen of your tv is made up of semi-conductors.
I would be very surprised if the set isn't a write-off.
Sep 04, 2015 | Samsung UN55C6500VFXZA 55in Led Hdtv 1080p...
How do I wire up a kicker ps60 powered substation?
Kicker Product Manuals KICKER
The above link should bring you to the Kicker manual page. On the menu boxes, choose ' sub boxes' on the left and ps 80-60 substations. Review the manual for hook up directions.
Jun 08, 2014 | Car Audio & Video
350kv substation single line digram
What is the relation between 350Kv distribution sub-station and a TV?
Mar 25, 2013 | Televison & Video
I need to know what to put the frequency at for my subs... they are 2 12" kicker comp's
40 - 45 Htz is the usuall. It really depends on the music you listen to. They are built to handle a little more mid bass. Where they are located, power supplied, direction the subwoofer is facing will all have an effect on what you need to set it at. My suggestion is follow the basic steps in setting up your amp. 1. turn your amp gain all the way down. 2. turn your radio volume to 75% of max. 3. start turning up the gain until you obtain the sound you want. You want to do this so your don't "clip" the sub. Kicker is good, but the comps can only handle so much before they start popping. This will heat up the voice coils quickly and cause them to fail prematurely. Hope this helps.
Jul 31, 2011 | Car Audio & Video
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
Car speaker are popping when turn up louder
This is probably clipping from gains being set improperly. Use the proper method for your amplifier and a test tone cd and multimeter to set the gains at the proper level.
Mar 14, 2011 | Kicker Car Audio & Video
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
My amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
Mar 20, 2009 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
32 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
