Question about Uniden 5.8GHz Dual Cordless Phone
How do I leave new greeting?
I need to replace my greeting. How do I do that?
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
Listen
Listen to the current greeting or the new greeting just recorded.
Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
More
Switch between the different sets of available soft key functions.
Submit
Submit the new recording as your mailbox greeting.
Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 | Avaya 1408
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I lost manual. I need to know change message when will be out of town answering message.
announcement.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Dec 03, 2010 | Uniden DECT 6.0 Cordless Phone ID
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
New GE Model 28821 Answering System HANGS UP after greeting announcement! HELP?! ;P
JUNK IT AND GET A PANASONIC.. THATS WHAT I DID. THIS GE PHONE IS THE WORST.
Jul 24, 2008 | Uniden Cordless Phone
Would like to change voicemail message in phone
-Dial into voicemail
-Enter password to access system
-Press button for Greetings or Administrative Options menu
-Choose type of greeting
-Press button to change it and record new greeting
-Listen to new greeting and press button to confirm
-Exit system
May 02, 2008 | Cell Phones
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
User manual of GE 29878GE1 Digital Answering Machine
From the Manual: RECORDING THE GREETING Before using your new answerer, you should record a greeting (the announcement callers hear when your answering system answers a call). If you don't record a greeting, callers hear a default greeting which says, "Record message after tone." When recording the greeting you should be about 6 inches from the unit. Eliminate as much background noise as possible. 1. Prepare your greeting. Sample Greeting: Hi, this is (use your name here). I can?t answer the phone right now, so please leave your name, number, and a brief message after the tone, and I?ll get back to you. Thanks. 2.Hold down the GREETING button. After the tone, you have 30 seconds to record your greeting. 3.Release the GREETING button when you finish. The greeting will playback automatically. NOTE: Your recording time should not be less than 2 seconds. Otherwise the unit will return to the default greeting.
Jun 05, 2007 | GE 29878GE1 Digital Answering Machine
Uniden 5.8GHz Dual Cordless Phone Logo
22 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
