Question about Teac PD-H300 CD Player
Cd not spinning
Cd loads but does not spin
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
Open top Cover of drive, open tray, close tray.
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
RCA RP 3755 Clock radio: CD player will not spin
Hello
Check the voltage at the terminals of the sled motor. If it is found OK, replace the sled motor. Sled motor do spins the disc inside for any CD players. See the picture of its position.3_1_2012_3_05_08_pm.jpg
Feb 29, 2012 | RCA Audio Players & Recorders
Cd player won't spin disc
HelloCheck the sled motor. it is the motor that spins the disc inside, as soon as it has been loaded. Check the voltage comes to the leads of the motor first. If the voltage is there, and the motor does not spins, repalce the motor. It is a stepper motor, can be bought from most of the electronic spare part shops at your town. it is not a very colstly component. OK.
Dec 19, 2011 | Sony Audio Players & Recorders
My MegaStorage Sony CDP-CX250 won't play any CD. The carousal turns to loading position, the cd is loaded, but nothing more happens. It can't spin at all. The CD is then unloaded again. The...
I would check the drive is not blown, as that is what sounds like has happened
take a 5v dc feed and run two wires to the motor to see if it spins up ,if it doesnt spin replace the motor , if it does spin then the problem lies else where in the circuitry
Jun 25, 2011 | Sony CDP-CX250 CD Player
I load the CD put I don't hear it spinning at all
No it isn't, because your switch isn't tripping when you close the DVD. Try holding the lid down with your hand and listen for spin. If your DVD starts spinning you will need to locate the plastic pin protruding from your lid and extend it with superglue and a piece of cardboard. This will make up for the warp in your lid, and allow the switch to close.
Mar 09, 2010 | Mintek MDP-1810 Portable DVD Player
Unable to Connect
If the CDROM spins and stops, spins and stops then the drive is bad and needs replacing. If the drive spins without interuption try using my computer to browse the CD.
Jun 03, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
I works mechanically, but doesn't play the CD
try cleaning the lens first use a lint free swab and GENTLY clean the lens. don't use any liquid on this. if that doesn't work then load a disc and gently spin the disc when it lifts into load posistion. if begins to spin on it's own then replace the spindel motor. if it still does not spin, replace the optical pickup, the EF sensors inside the pickup no longer have the ability to read (see) the disc.
Feb 03, 2008 | Teac PD-D2380 5-Disc CD Changer
Teac PD-H300 CD Player Logo
91 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
