Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice machine not working, don't think the water is going thru the pipe area although I can get water from frig
  • Anonymous Nov 06, 2007
    Icemaker stopped working but I still can get water from dispenser.
  • arr0142000 Dec 09, 2007
    I have the same problem. I can get water from the dispenser but no water flows to the ice maker.
  • 35 Answers
Replace the IM module.
Posted on Dec 09, 2007
I have a maytag side by side frig model # msd2578vemoo the ice machine works but the water dispenser does not work
You will need to replace the water inlet valve on the back of the refrigerator. One line is for the water dispenser and the other is for the ice maker. The side for the ice maker is not energizing the solenoid to let the water thru to the ice maker. Here is the part you need to order.
Nov 10, 2012 | Refrigerators
Water is draining into the refrigerator. It fills
Good day,
In the freezer if it has an ice maker, it will have to be removed.
Remove the back panel. Below the cooling coil is a drain pan.
It has a drain hole in it. If it is iced over you will have to defrost it, with the machine off.
Many use a hair dryer, but hot water with a turkey basting tool is
safer.
Once the drain hole is open, you will have to follow thru since the water drains into a cup in the fresh food compartment then thru the back wall into a drain hose on the rear.
Blockage can occur anywhere thru that area.
Service techs usually use compressed air with a hose to blow the lines clear.
If you have no access to something like that you wil have to get creative. Removing all the components and flushing them out is one option.
Aug 02, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
The refrigerator side is not cooling though the freezer section is working.
Check in the frig side upper left at the top. The frig has to be running. There are air vents that bring the air to the frig side. If you dont feel any air this is what could be the problems with that:
Freezer fan not running
vent is closed
vent is iced up
evaporator is iced up
try to determine which one of these it is or not...
let me know and we will go from there
hope this helps
Mar 30, 2010 | KitchenAid Architect 25.3 Cu. Ft....
My roper frig it has water inside under the vegie
clogged freezer drain in freezer. remove cover and work some hot water in and out of the drain with a turkey baster until water runs thru and then poutr more water thru drain until all ice is washed thru. good luck.
Jan 20, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My Maytag side by side with water dispenser and ice maker doesn't work. We bought a house - never lived in - and the fridge and freezer work fine. We replaced the water filter and find that no water comes...
The sadle valve is located on the copper pipe where the tube attaches to your water pipe in the house. Shut the water off at the saddle valve. Remove the hose from the rear of the frig on the water inlet valve and put it into a pail. Tunr the water on at the saddle valve and see how fast the water comes out. Some times if the saddle valve is installed on the bottom of the copper pipe they will get corrosive and restrict water flow. Open and close the valve several times to make sure it is clear and reinstall the hose to the rear of the frig. Turn the water back on to see if it works.
Dec 29, 2009 | Freezers
My 1-year old whirlpool fridge ice maker has stopped working
from the back of the frig follow the water line to where hooks to the house water line once you find it turn it off all the way and tightly then open it all the way up.......because if its located on the bottom of the pipe sometimes it plugs up and you'll clear it this way
Sep 06, 2009 | Refrigerators
I am getting no water to go into my ice maker ,m
Whenever water is run to a refrigerator icemaker there is a filter. Depending on the composition of your water, your filter can get a build of of chemicals that are found naturally in water. Change out the filter. If that doesnt work... work your way backwards.. check the copper pipe that runs from the wall to the frig to ensure it did not get bent or cracked while moving the frig out to clean, etc.. Hope this helps. Good luck
May 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Kitchenaid Icemaker with Aqua Sense is not working.
If the freezer was shut off for a time, then the water in the feed tube may have frozen when the freezer was turned back on. Check to see if there is ice in the mold. If empty, then the feed tube is clogged or frozen (or else the water inlet valve may have failed, less likely).
Feb 26, 2009 | KitchenAid 22.0 cu. ft. Side-By-Side...
Ice maker freezing up
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
Oct 16, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
48 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
