Question about Canon P126D Calculator
Arrow left is on - Canon P126D Calculator
HOW DO I ROTATE MY SCREEN USING SHORT-CUT KEYS
Depending on your driver, it can be ALT + left arrow (or right arrow), or CTL + left arrow (or right arrow), or MAJ + left arrow (or right arrow), or any combination of ALT, MAJ, CTL plus one of the direction arrow...
Nov 08, 2014 | Microsoft Windows XP Home Edition
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
When I type 12!/5!7! I'm getting 2.01180672e10. My answer is suppose to be 792. Please help.
Somehow you're calculating 12!/(5!/7!).
Press 1 2 MATH left-arrow 4 / 5 MATH left-arrow 4 / 7 MATH left-arrow 4 ENTER to calculate the desired value. Alternatively, you can press 1 2 MATH left-arrow 3 5 ENTER or 1 2 MATH left-arrow 3 7 ENTER to calculate the same thing.
Aug 10, 2011 | Texas Instruments TI-83 Plus Calculator
I have a laserjet 2600n - the black prints perfectly but where i have colour, especially the blue and red, they seem to shadow each other. if i have a web address, when i go to print it there will be the...
May just need a calibration.. Try this:
  1. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads System setup and then press c00314544.gif (SELECT).
  2. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Print quality and then press c00314544.gif (SELECT).
  3. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Calibrate color and then press c00314544.gif (SELECT).
  4. Press the c00314542.gif (LEFT ARROW) or c00314543.gif (RIGHT ARROW) button until the display reads Calibrate now and then press c00314544.gif (SELECT).
  5. Press the c00314544.gif (SELECT) button to confirm Calibrate now.
Jul 20, 2011 | HP Color LaserJet 2600n Printer
My left click button is not functioning and I can't figure out how to highlight text without it...
You have to use Tab and Arrow key to highlight object,But for text
Shift + Left Arrow will take you to the right alphabet.
Shift + Right Arrow will take you to the left alphabet.
Shift + Ctrl + Left Arrow will take you to the right word.
Shift + Right Arrow will take you to the left word.
Hope will be little helpful to you.
But I suggest you to get an external USB mouse.
Jan 02, 2010 | ASUS Eee PC 900 Notebook
Unlocking a Sony Ericsson I580
press * left arrow press * * press left arrow..
Aug 04, 2009 | Nokia 6233 Cellular Phone
Have Lexmark X9350 All in one - Need to block incoming junk faxes
You can find these instructions on page 140 of the User's Guide. The English User's Guide is here: http://images.lexmark.com/publications/pdfs/2007/9300/v1116690_en.pdf
If you have Caller ID, you can block faxes sent from specific numbers and/or all faxes which do not include a Caller ID number.
To turn on the Block List feature:
  1. From the control panel, press up arrow or down arrow repeatedly until Fax is highlighted.
  2. Press select (checkmark).
  3. Press up arrow or down arrow repeatedly until the Fax Setup submenu is highlighted.
  4. Press select (checkmark).
  5. Press up arrow or down arrow repeatedly until the Fax Blocking submenu is highlighted.
  6. Press select (checkmark).
  7. Press up arrow or down arrow repeatedly until you reach the Block List menu item.
  8. Press left arrow or right arrow repeatedly until On appears.
  9. Press left curved arrow to save and exit.
To add each fax number you want to block:
  7. Press up arrow or down arrow repeatedly until you reach Blocked Fax Add Entry.
  8. Press select (checkmark).
  9. Use the keypad numbers to enter the name of the person associated with the fax number in the Name field.
  10. Press down arrow once.
  11. Use the keypad numbers to enter the fax number in the Fax Number field.
  12. Press left curved arrow to save and exit.
To block faxes sent from an unidentified number (a number with no Caller ID):
  7. Press up arrow or down arrow repeatedly until you reach the Block No-ID menu item.
  8. Press up left arrow or right arrow repeatedly until On appears.
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Hp laserjet 2660n prints every page on red background even from auto testing; I have just bought it.
This is a common problem with this printer. Try this and it must be done 3 times in a row. Also, sometimes if there cartridges are not all from the same maker there may be issues. The transfer belt can be changed but it requires removing a few covers.
Calibrate the printer at the control panel of the printer
Aug 04, 2008 | HP Color LaserJet 2600n Printer
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Canon P126D Calculator Logo
52 people viewed this question
old marine
old marine
