Question about Canon P126D Calculator
Arrow left sign is on
Arrow sign on
How to reset Netflix using neo device
Please follow these steps to sign out of netflix on your netgear NEO device:
  1. Launch the Netflix app.
  2. Using the arrows on your remote, enter the following sequence:
    • Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
  3. Select Sign out or Deactivate.
Jun 22, 2014 | Televison & Video
Tip
Shortcuts you can use with Windows Explorer
Display the bottom of the active window. END
Display the top of the active window. HOME
Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)
Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)
Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)
Collapse current selection if it's expanded, or select parent folder. LEFT ARROW
Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW
on Apr 04, 2011 | Computers & Internet
Tip
Acessability shortcuts
Right SHIFT for eight seconds........ Switch FilterKeys on and off.
Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.
Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.
SHIFT....... five times Switch StickyKeys on and off.
NUM LOCK...... for five seconds Switch ToggleKeys on and off.
explorer shortcuts
END....... Display the bottom of the active window.
HOME....... Display the top of the active window.
NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.
NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.
NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.
LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.
RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.
Fx-82ES How to use the replay button?
After you execute a command (=) and have the result displayed, you can press the Left Arrow of the Replay button to move the cursor to the end of the last command line.Use Left arrow/Right arrow to move cursor along the line and modify it (change a value, operation sign, etc.) After you make the changes press the = sign to execute the modified command.
Jan 30, 2012 | Casio Office Equipment & Supplies
Just been given a ASUS Eee PC 900, with Linux. It says press the Enter Key, but I can not find a Enter Key as such. What key do I have to press.? Driving me crazy
Well, the Enter key is the one with the symbol of a left-pointing arrow with a short 'up bit' on the right-hand side of it. I think its to the right of the @ sign and on the same row. Incidentally the OTHER left-pointing arrow without the up bit on it is the backspace. Thats up above the Enter key also on the right-hand side of the keyboard. Regards, nicam49
Aug 16, 2011 | ASUS Eee PC 900 Notebook
6.6 x 10 to the -8 exponent divided by 3.3 x 10 to the -4th=
Type in
6.6 [EE] [+ -]8 [/] 3.3[EE] [+ -] 4 [=]
The [+ -] is the change sign key. It has a + on the left, a minus on the right and two rounded arrows. The top arrow goes from left to right and the bottom one goes from right to left.
Aug 31, 2010 | Texas Instruments TI-30XA Calculator
How do i turn off the date/time on my kodak easyshare m863?
Press the MENU button. Use left/right-arrow to select the Capture tab (the camera icon without the "+" sign). Use up/down-arrow to select "Date Stamp" and press the OK button. Select "Off" and press OK.
Jun 08, 2010 | Kodak EasyShare M863 Digital Camera
Where is the negative button, I need to use negative numbers?
There is a key with a "+" sign, 2 arrows and a "-" sign. After you enter a number, hit this key to change it's sign. Hope this helps. Good luck!
Mar 04, 2010 | Texas Instruments TI-30XA Calculator
My TI--84 plus calculator won't display the 7 graph modes, and it won't graph equations simultaneously. What is wrong? I can only get an arrow icon and an arrow-bar icon.
Use the [Y=] entry screen to enter the functions you want to graph. Make sure that the = sign after Y1, Y2 etc. is highlighted (black). If the = sign is not highlighted the corresponding function will not be drawn. You can can up to 10 functions, but what is the point of drawing so many if they overlap?
Anyway, to change the graph style of the curve for a particular function, use arrows to move to the line, then use left arrow to the bit of line that appears to the left of the Y. Highlight the segment an press ENTER. Each time you press ENTER the style changes to another one. Beware of the unconnected bubble style. During the drawing it will show the position of the point being drawn, but at the end, the whole curve, so to speak, evaporates.
As to simultaneous graphs, if it is important to you to have the graphs drawn for all the curves at the same time, you can enforce that by pressing [MODE], and using down arrow to reach the 6th line Sequential Simul. Use the right arrow to highlight Simul and press ENTER.
Whether drawn sequentially or simultaneously, all graphs will be displayed, except for the ones with the unconnected bubble as style.
Hope it helps.
Oct 02, 2009 | Texas Instruments TI-84 Plus Calculator
DO NOT KNOW WHAT THE SIGN MEAN. DONT HAVE A MANUAL
If it looks like this (!) its your tire pressure light..
Aug 13, 2008 | 2007 Toyota Camry
Canon P126D Calculator Logo
26 people viewed this question
old marine
old marine
