HOW DO YOU CHECK THE OIL LEVEL IN A 1981 HONDA 1100GL
There is a dip stick located on the right side of the engine about 4 inches to the front of the oil fill cap.
Make sure you are on level ground. Unscrew the dip stick and wipe it off. Replace the dip stick and then remove again. Check the oil level and replace. If you need to add oil, remove the filler cap and add oil 1 to 2 ounces at a time. Check the oil dip stick to ensure that your oil level is correct.
NOTE: warm up your bike before performing the above checks.
Regards,
Oz
If you find this helpful, please vote on it. Thank You.
