Question about Hoover Max Extract Steam Cleaner
Do not know where the small round coil spring goes
Where to put coil spring
I took apart my Eureka 71B hand held vacuum and a small spring fell out. I don't know where it goes and can't find a manual anywhere. Help?
Lonny,
I have a 71-B2 model myself and if you can take a picture of the spring, I can try to take mine apart and see if I can figure out where your spring goes and get back with you.
Aug 09, 2015 | Eureka 71B Easy Clean Hand Vacuum Yellow
Switch Assembly
one spring larger goes on the red on /off small spring goes on the little white piece
Apr 05, 2014 | Dyson DC40 Multi-floor Vacuum DC40
The wheels with the spring broke off and I'm trying to put a new one on but I don't know where the spring goes.
This spring can be very confusing to install. It slides onto the wheel assembly near where the attaching pin is longer ( there are flat protrusions on both sides of the wheel assembly). One end of the spring pushes up on the assembly when it is in place, and the free end must be pulled down and inserted into the small slot in the bottom of the base. Pull down on the shorter end of the spring, holding the longer end, and slide it onto the round area on the wheel assembly. As you put the wheels back on, pull on the longer end and insert it into the slot in the base.
Jan 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
Bissell proheat used does not put out water
The spring your talking about goes where the trigger switch is. You need to dismantle the entire unit to access this, remove 6 screws on hood, two main handle screws, two tool caddy screws and finally two lower back housing screws. Removed top handle and gently open unit up
Aug 29, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
When I took the base cover off the vacuum to clean the roller, a metal piece that is bent in half, as well as a white plastic stick piece came flying out. I think it might have to do with holding the...
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Aug 09, 2009 | Eureka 411A Upright Vacuum
Nilfisk king 540: The cable is stuck. I can´t take it out
Tools required: Haxalobular screwdriver (Torx or 'Star'), Strong hands/fingers, flathead screwdriver.
Possible hazards: sharp edges (metal plastic), bacteria enriched dust/dirt.
Notice the black ring/skirt near the bottom of the unit...sit on the vacuum cleaner, and pull very firmly at the ring, which will begin to click and pull upwards, rotate around the unit pulling the ring up until the whole ring comes off and you can pull it off over the top of the unit.
Now, there will be a white plastic ring revealed around the unit, using a Flat Head screwdriver to pry the ring out of the grooves it sits in (pull it off towards the bottom of the unit as opposed to the intial black ring coming off upwards).
Now take the handle of the unit and give a firm **** upwards, the whole encasement will slide off in your hand.
You will now see the spring loaded cord retracter. The problem here is that the spring has become too losely wound back onto the larger spindle, or it is dirty.
Firstly pull the entire power cord through the outer shell that you removed (you will need to unscrew and remove the black facade that the cord goes through otherwise the head of the cord wont go through).
Then take the plastic cirlce cover off the smaller spindle (carefully as the wound tin spring could pounce).
Now you need to manually turn the larger wheel clockwise until it has no coil left on it, and the smaller coil now is full.
While winding, dont let the powercord wind back onto the wheel, let it sit to the side (there will be a bit of tangle which will go back to normal when we finish winding back the other way).
Once it is fully loaded onto the smaller coil, wind it back on to the larger coil again, but make sure it's loading on 'tight'. You can ensure this by keeping some pressure on the smaller spindle while winding (be carefull because the coil edge is sharp). Once the smaller coil is basically gone and there is just a small curved end of the coil, put the small spindle back on making the curved coil wrap around it.
Wind some coil back onto the smaller spindle so there is atleast one full ring plus a small overlap, around the spindle, or it may come off. Also, make sure that where the cord is coming out of the larger spindle, is pointing towards where it goes out the back of the vacuum cleaner, so that when you pull the cable it wont wind the wheel at all, otherwise it may wind some coil off the smaller spindle.
Proceed to put the unit back together, but before putting the white and black rings back on, test the retract button. I noticed the first attempt to put it back together that the external button had not lined up with the internal mechanism and it wouldnt retract, i had to open it again.
All done, it should now retract, but it will never be as strong as the day you bought it, but atleast you dont have to have the cord hanging round. Hope this helps.
May 18, 2009 | Vacuums
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Hoover Max Extract Steam Cleaner Logo
11 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
