Question about Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028
Sfn-1 finisher connect
Error sc542 service
SC 542 Fusing temperature warm up error.Fusing lamp defective,poor fusing unit connector,thermistor warped or broken,thermostat has tripped,power supply defective.After verify the componenets try reset the error.Enter in service mode:Press the yellow key and press 107 and keep pressed the stop key 3 second.Touch the SP window on screen open the front door and turn OFF the copier.Wait 1 minutes ,close the front door and turn ON the copier.If the error code persist change the upper fuser roller and the thermistors.
Jan 01, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh MP 3351 shows messege SC798 , problems with finisher
Three possible cause:
- Poor connection between the finisher and mainframe.
- Finisher harness damaged or defective.
- Finisher unit defective.
For number 1 you can check the connection to make sure the connection is proper.
For number two and three, I am afraid you have to buy a new replacement unit.
Nov 09, 2013 | Ricoh Aficio MP3351
Sir bluestaks is not installing in hp 2133 mini laptop ,Sfn : CNU8241BMT,pfn : FH48gPA#ACJ,because there is no graphic card. Then how to install bluestaks.
The netbook hardware is not sufficient to support Bluestaks and with no decent graphics card it will never work, I am afraid you will have to forget the idea or try installing on laptop or desktop PC.
Oct 01, 2013 | Computers & Internet
Senco SFN 2 needs part # LB5005 seal and # KB 5061. Where can I get these parts or repair kits?
Best place for Senco parts is www.juldan.com
They have both of these parts in stock with good pricing. Good luck
Apr 09, 2011 | Senco Tools & Hardware - Others
The Senco SFN-1 gun will drive one nail and then not retract
sounds like time for a rebuild i do this once a year on all of my guns i buy a seal kit and replace them at that time and oil the interior oparts and check for worn or broken parts
Sep 03, 2009 | Senco Tools & Hardware - Others
Greetings, I have a Senco SFN-2 finish nailer.. I put a new senco kit in it... It fires upon connecting air to it but then leaks like crazy at the trigger...???? Why, why, why....???? Looking for a diagram...
you have popped the seal too much air pressure. Ive done it my self lol. diagram dont know sorry but it dont have very many parts should be easy to fix. good luck.
May 08, 2009 | Air Tools & Compressors
Is my tv digital ready?
If you have cable or satelite hooked up to it now and it works,Then it is digital ready.
Please rate this a fixya
Feb 13, 2009 | A D S TV Superscan 2 (SFN-201)
Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028 Logo
37 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
