Question about Amana 3.2 cu. ft. Top-Load Washer
Slow filling changed out water value, still slow filling
  • 44 Answers
Is your water valve fully opened?? Check the water shutoff valve and ensure that it is fully opened. IF it is, then do a simple test by disconnecting the hose from the washer, and get a large bucket, and turn on. If strong flow, then you may have some sort of clogged screen inside the washer (check inside the inlet connection).
Posted on Mar 21, 2014
Scotsman ice machine slow water fill
Check to see if there is a water filter inline if so then change it. If not then check where the supply water line is hooked up to the machine pull line off and turn water on to make sure you have good water pressure. if you have good pressure then pull the water inlet valve and take it apart to make sure it is not stopped up with trash and that is it.
Mar 12, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Water diagnose light blinking 0n cm3 scotsman ice machine even after changing water level sensor
Is the sump tray full of water? or is it not filling up fast enough? Water level sensor lets control board it needs water or its full of water. If machine is not getting enough water or slow filling then check the water filter, if water is flowing good through filter good then pull water line off of the water inlet valve to make sure there is no trash blocking water at inlet. If not then make sure the water solenoid is getting power call from board to solenoid, if getting 115v to coil and slow to no water to sump then replace valve, if no power to valve then replace board.
Sep 25, 2014 | Kitchen Appliances - Others
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Cold water fill is very slow and makes strange sound
check with the plumbing work if that is fine then better take it to the dealer to change the inlet valve. attempting to change by yourself can cause other complications.
Oct 04, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Slow water to the water disper ice maker ok changed water inlet v
You could check and replace the filter, it could be clogged
Jul 17, 2009 | Whirlpool GS6NBEXR Side by Side...
Slow water fill
what make?you don't have to change the hoses just check the screens,if the screens are clean,than the water valve must be going bad,put in on cold only,put it on hot only,if one come out slow and the other does not replace the valve($20) mike
Apr 20, 2009 | Washing Machines
Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
Oct 19, 2008 | Maytag Washing Machines
Amana 3.2 cu. ft. Top-Load Washer Logo
42 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
