Question about Panasonic Toughbook CF-51 Notebook
How to select a boot device
I want to select the usb hard drive to boot to
    Novelist:
    Scholar:
  • Panasonic Expert
  • 105 Answers
The Panasonic Toughbook CF51 may not be able to boot
from a USB external Hard Drive. When you press the F2
function key and go to BOOT devices, I believe that USB HDD
is NOT an option. However, when the drive is plugged-in
and you start the CF51, press the ESC key immediately.
All boot devices should be shown and you might be able
to boot from that menu. If not, then it is NOT bootable.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Posted on Feb 08, 2016
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Reboot and select proper device or insert boot media in selected boot device and press a key.
Sounds like your computer is looking for a device to boot from and can't find one.
First step is to disconnect any temporary drives. Is there a USB flash drive connected? Is there an external hard drive connected? I have an external hard drive that if connected, will give me this error.
If this doesn't work, the next step is to go into your computer BIOS and set up the order of devices to try and boot from. If you are booting from a hard drive, it should be on this list.
Good luck,
Paul
Mar 12, 2015 | Microsoft Windows 7
Seen as movable
If you change the Boot Device startup order with the USB port as the first boot device then you can boot up with an USB hard drive or USB Flash device.
If your hard drive is the first boot device then your USB hard drive will not boot up first.
Aug 01, 2012 | Transcend 750 GB 2.5-Inch USB 3.0 Super...
How to format transcend 25 storejet 500gb
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jun 27, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Showing cannot format complete
hope this helps
May 25, 2011 | Computers & Internet
Reboot and select proper boot device
It may mean several things but the common ones are:
1.- Your hard drive is not beeing recognized by the motherboard
2.- Your hard drive might be damaged
3.- You need to enter the mother board configuration (usuallly by presing F2 on keyboard depends on the brand and model) by the moment of booting the pc and selecting boot options or device priority and selecting your hard drive as the first or default boot unit.
4.- You may need special drivers for your hard drive that may come with a floppy with your hard drive or you download from internet and load them of a USB drive (google for it)
5.- you may have a damaged system cd on your cd room.
6.- You may have some other boot device like a USB or Ethernet boot.
In any cases do only as I told DO NOT I repeat DO NOT touch any other thing than I say or you may crash down your pc.
Good luck
May 05, 2010 | Microsoft Windows XP Professional
I was trying to boot my pc from usb but it was noot bootable how to make usb drive bootable
Have had loads of usb media, as far as I know some USB sticks are bootable others are not, usually it will say either on the manual or on the box of the product whether its bootable. If it is bootable format the usb drive fully then copy the BOOT.INI, NTLDR, and NTDETECT from the root directory of your PC's boot drive to the flash drive. These files are hidden by default, so you will either have to configure Windows Explorer to show hidden files (including protected operating system files) or you will have to open a Command Prompt window and use the COPY command to copy the files. If you choose to use the Windows Explorer method, then open Internet Explorer and enter C: into the address bar so that you are looking at your local hard drive. Next, select the Folder Options command from the Tools menu. When the Folder Options properties sheet opens, select the View tab. Now, just select the Show Hidden Files and Folders and deselect the Hide Extensions for Known File Types and the Hide Protected Operating System Files check boxes. Click OK to continue.
Now that you have formatted your USB flash drive and installed the boot files onto it, the next thing that you must do is to configure your PC to allow you to boot from the flash drive. This is all done through the computer's BIOS Setup. I can't give you specific instructions for this part, because every computer is different. I can give you a few pointers though.
You can access your computer's BIOS by pressing a specific key immediately after you turn the PC on. The key varies, but it is usually either [F1], [F2], or [Delete]. Once you are in the BIOS Setup, you should verify that all of your computer's USB options are enabled. This might include things like support for legacy USB devices or support for USB 2.0. If there is a time out setting for USB devices, you should set it to the max to insure that the system doesn't time out while waiting on the USB device to boot.
Next, find the section on boot device priority. Normally, a USB flash drive (which is usually listed as USB-HDD, but may be listed as a removable device) will have a very low boot priority. If the USB flash drive's boot priority is lower than the hard disk (listed as HDD) then the only time the computer would ever boot off of the USB flash drive is if the system were to fail to boot from the hard disk. You must therefore rearrange the boot device priority so that the flash drive has a higher priority than the hard drive.
Jul 01, 2009 | SanDisk Computers & Internet
How i can get usb drive to startup disk
download USB boot system... or USB bootable disk software
Jun 16, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Boot windowsxp from USB drive not from Cd/Dvd drive
Your BIOS would need to support booting from USB. If it does then you would see the option 'Boot from USB' in the section of your BIOS where you select the boot order. Select the Boot from USB option then set the USB drive to 1st boot device.
Apr 29, 2009 | Samsung SpinPoint SV1604E 160GB U133...
Panasonic Toughbook CF-51 Notebook Logo
372 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
