Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Fax error ng b0 - Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Toshiba DP 125F What do these status codes mean: a)NG B0 b)50 Also how do I fax to a long-distance number if adding long distance code?
If you mean by "50", Device Error 50, make sure the cable is firmly connected between the main motor and the Mother PBA (CN3), between the Mother PBA (CN24) and the Main PBA (CN12). Otherwise, replace in this order:
1. Main motor.
2. Main PBA
3. Mother PBA.
Jan 12, 2011 | Toshiba DP125F All-In-One Laser Printer
What does NGB0 mean on the activity report?
NG is shortcut for "No Good", indicating a problem. "B0" is the fault code for a communication problem, usually caused by an incompatible setting of communication mode G2 or G4 on the remote machine.
Contact the remote operator and ask he set up his machine for EECM or G3 communication mode, then retry.
Jan 06, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
Oct 09, 2009 | Canon LaserCLASS Fax 710 Printer
Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Cannot Send Faxes
Problem:
Not sending to long distance and government sites with encyrptor. Note: NG is not actually part of the Fault Code. NG stands for No Good on the Activity Report. Cause:
Not enough time to hand shake. Another cause of B5 can be a faulty Main PWB. Note: Should you wish to change the Main PWB, consult the following ETI 170535 to insure that you are selecting the correct part number. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. On speed dials and one touch numbers that the Customer is having problems with, you will have to modify the number to be dialed. What you have to do is add pauses to the end of the number. (example 555-5555 does not send to, error B0 (that is B Zero ) every time / then start adding pauses at the end of it until it works. Example 555-5555#. in some cases in Winnipeg and surrounding areas we have had to put up to 6 pauses to get a successful send. Note 1: These were to Fax Machines with encryptor devices and long distance...Avoid Call Backs. Inform the Customer of this. LEAVE instructions on how to do this. This will save your and your Customer some headaches. Note 2: Some success has been found by turning off the V34 Modem
Apr 16, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Sending fax
NG STANDS FOR NOT GONE , TYPICALLY THIS MEANS THAT THERE IS A COOMMUNICTION ERROR AND THERE IS ALINE DISTURBANCE /NOISE DURING THE CONNECTION WHILE SENDING THE FAX MESSAGE. TRY CHANGING THE TELEPHONE LINE IF IT IS AVAILABLE. HAPPY FAXING OMNIPRESENT
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
