Question about VuPoint Solutions - PDS-ST450-VP - Magic Wand W/docking Base
Scanner won't work
Ed the battery, inserted the microSD, set the time and date. Tried to use the docking station, but the rollers would not turn to draw in the paper. I took the wand out of the port and tried to use it manually. Step 4 says to "press the SCAN button once. GREEN SCAN LED light will be lit". It did not light up.
3 Suggested Answers
SOURCE: I can't figure out how
Hi Karen,
Do you have a micro scan disk inserted? The scanner will not work without one. Insert the disk in the slot next to the Format button. Turn the unit on then press the format button to format the disk. To scan a document, you press the scan buttton once, then release the button. Slowly move the wand over the document to be scanned. When you have finished scanning, press the scan button once again.
Hope this helps,
Marcus
Posted on Nov 02, 2010
SOURCE: I cannot get mu VuPoint
I had the same problem until I set the time and date. Not sure if this was the problem but it worked after setting these things. I went through the "Using the Scanner" section in the documentation.
nic
Posted on Dec 26, 2010
How do I replace document feeder,broken?
Hi
You state that this "was new out of box" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 26, 2015 | PANDIGITAL Handheld Wand Scanner Wfeeder...
How do you set the time on RC591-A (RCA Docking Alarm Clock)
None of these answers works! When I tried the first option, the clock DID NOT flash at 12:00 a.m. Since that didn't happen, none of the following steps did either.
The second option didn't work either. Holding the set key never made the display go to a colon, flashing or otherwise. Again, using the forward and back keys didn't work as described.
The third option with a link to another website led to instructions on a power tool and had nothing whatsoever to do with the clock on the docking station.
The fourth option doesn't give any instructions after you hit the time you want to set. The time DOESN'T stay where you set it. It once you release the forward or backward keys, it reverts to the original time that was on the clock to begin with.
None of these answers works at all. I was given the iPod touch and the radio docking station secondhand from my sister and she doesn't have either the instruction manual or the special batteries that go in the battery compartment. The clock on the iPod itself is fine. I finally figured out (on my own) how to turn off the danged alarms and timing mechanisms but cannot set the clock.
Nov 07, 2011 | Audio Players & Recorders
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
Acer EzDock
Try updating all the drivers, including the one for the docking station, from the acer website.
Jul 26, 2010 | Acer EZDock (LC.D0303.005) Docking...
HP Elitebook 8540p is getting no video in docking station
Try this
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=au&prodTypeId=321957&prodSeriesId=4097214&swItem=ob-83668-1&prodNameId=4096169&swEnvOID=1093&swLang=13&taskId=135&mode=4&idx=4
Jun 23, 2010 | HP EliteBook 6930p Notebook PC
E5500 will not turn on after disconnected from docking station
I just want to know, removing battery and docking station, and just use the ac adapter alone still no power on the laptop? If yes please replace the motherboard.
Mar 31, 2010 | Dell Latitude E5500 Laptop
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
No memory card, set time
The date/time battery is "built in" (not replaceable) to this model according to page 13 in the manual (available here). It is supposed to recharge when you have the regular battery installed, but if you leave the regular battery out for more than "approximately three weeks", the internal battery may go flat.
I'm not sure this has anything to do with the memory card issue, though. Check the battery problem by inserting a freshly charged battery, turning on the camera and setting the correct date and time, then turning off the camera and waiting an hour or so (with the main battery still in the camera). Turn the camera back on, and if the date and time have to be reset again, your internal battery may be bad, and the camera would need to be serviced.
Dec 09, 2008 | Canon PowerShot SD870 IS Digital Camera
Camera won't charge
Hi!
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
VuPoint Solutions - PDS-ST450-VP - Magic Wand W/docking Base Logo
428 people viewed this question
Top VuPoint Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a VuPoint Craft and Hobby Expert? Answer questions, earn points and help others
