How can I get spark back to my motorcycle
double posted to wrong forum,
if you are serious with DIY work, why not buy the FSM for your bike
and read the page called spark generation.
its all there. read it,
you never posted make, model , year or engine, nor country sold.
so there will be no answers, and for sure on Truck forum.
Vitara is a truck not a bike.
on most motor cycles, (I restore them too)
the old bikes can have 2 parts, a CKP sensor and a coil.
either can fail , and the coil can be bench tested easy.
saving the guess work. ask.
the newer bikes, (no year stated) have EFI.
EFI works like this.
CMP +CKP sensors>>>> ECU>>> ignitor>>>>coil
on bikes like this you connect a scan tool and crank
it will tell you what is bad if its CMP or CKP sensors bad.
saving 1/2 the guess work.
then test coil , if coil ok.
then the ignitor is bad.
or use a scope, i use a scope and go right to the cause. direct.
like all cars and bikes, the tools you have, solve the problem fast.
if no tools , then GUE$$
or get it fixed.
