Question about Gateway PC Remote Control
Gateway remote Can I use a gateway remote on all gateway computers?
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: replaced Gateway 105552 Foxconn C51GU01 Motherboard with another
Was this also the original problem pedro1952?
Computer doesn't start up?
Removed Ram Memory, and no BIOS Beep Code/s.
Shouldn't have been. Ram Memory needs to be in there.
Primer:
You press the Power On button. This in turn presses against a Power On switch, located within the plastic Power On button.
When the Power Supply is plugged into power, there is a 5 Volt Standby power, present in the Power Supply.
Pressing the Power On switch closes a circuit, that directs the 5 Volt Standby power to the Power Supply.
This excites the Power Supply, and turns the Power Supply on. (No don't go there, lol)
The Power Supply directs power to the motherboard.
The first chip to receive power is the BIOS chip.
(Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit )
The BIOS program is 'burned' into the BIOS chip.
BIOS looks to see what devices are installed, DOES a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP is one example of an O/S)
Unless you KNOW the motherboard is bad, I suggest you check the voltage power rails of the Power Supply, for the correct voltages.
[Unless you KNOW the motherboard is bad. One case in point, is that you have observed bad Electrolytic Capacitors on the motherboard. If this is true, then yes, it's obvious the motherboard is bad.
To expound:
A) http://www.capacitorlab.com/visible-failures/index.htm ]
Unless you know for a fact that the motherboard is bad, I suggest your Power Supply is bad. Weak Voltage power rail.
Not enough power to turn the Processor on.
Your Power Supply is rated in Wattage.
(Voltage times Amperage = Wattage)
If this is in reference to a Gateway GT5058, it comes with a 300 Watt power supply.
Gateway Support > GT5058 desktop computer > Support Documents,
http://support.gateway.com/s/PC/R/1008847/1008847nv.shtml
(In the main menu shown, left-click on Components.
Scroll down to the heading - Power Supplies)
1) ALL the LED lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is, as to how much Wattage it will use, at maximum operating capacity.
The Gateway GT5058 comes with an AMD Athlon 64 X2 3800+,
processor.
(In the main menu left-click on - Specifications)
Uses a Socket 939 processor socket.
(Components >Motherboards > Specifications > CPU Support)
The AMD Athlon 64 X2 3800+ may use up to 89 Watts. (That uses a Socket 939 processor socket)
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_processors#Athlon_64_X2
Power for LED lights, plus perhaps spin fans a few times, but isn't enough to turn the Processor on.
This is why you can connect the optical drives, with the 24-pin ATX main power cable unconnected, and they have enough power to open and close, and the LED lights, light.
You plug the 24-pin ATX main power cable back in, and you are providing power for the Processor.
There isn't enough power for the Processor, and especially not enough for the optical drives, AND the Processor at the same time.
The Processor is 'stealing' all of the power. Not enough power to open and close the optical drive tray's, or even light the LED lights.
No Processor operating, there isn't anything to search for the boot sector on the Harddrive.
The harddrive may not have enough power either, to spin the Platters inside.
http://computer.howstuffworks.com/hard-disk.htm
Have a cheap multimeter? Just need an economical one for this test. ($5 to $10)
You will be testing the 12 Volt power rail.
11 to 13 Volts indicates a good Power Supply
Less than 11 Volts indicates replace the Power Supply.
If not, is there a KNOWN to be Good, Compatible power supply, in an unused computer available?
KNOWN to be good.
Not one out of an old computer, that you have no idea if it's any good.
Compatible:
Has to have the correct power cables, and the correct amount of power cables.
Posted on Jul 10, 2010
budmrtn
  • 11361 Answers
SOURCE: my gateway monitor flashes gateway logo then it (FPD 2185 W)
Look for bad DC filter caps in the power/inverter board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Jul 27, 2010
Tip
How to setup VPN on a D-link Router.
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
on Feb 11, 2010 | Computers & Internet
Product specs
Go here to download your manual:
Oct 17, 2013 | Gateway Computers & Internet
I am able to connect 80.0.75.60 server remotely ..in that i need to connect to one of my application server 80.0.75.62. i am unable to connect. actually servers are in sum other place. while pinging to...
The gateway at the remote end may be down. Ensure that the remote gateway runs fine. See whether the application server (80.0.75.62) has communication with remote gateway.
Sep 27, 2010 | D-Link DFL-800 Firewall
I HAVE A GATEWAY DESKTOP GM5661E. THE TV
Manual located here:
http://support.gateway.com/s/PC/R/1015012R/1015012Rnv.shtml
For more specific onfo, get your computer's serial number and enter it at the following website:
http://support.gateway.com/support/default.aspx
Hope this helps.
Apr 15, 2010 | Gateway Computers & Internet
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Lexmark x2500m printer do not communicate with Gateway laptop
GAteway..not surprised. phone or email Gateway get some help..its the computer problem.
Nov 21, 2008 | Lexmark X2500 All-In-One Printer
Sabrent 5 in 1 adapter usb-dsc5
Gateway hard drive need to be "slave"
usb need to be inserted before turning on the PC.
Oct 05, 2008 | Sabrent Computers & Internet
Gateway AR-230 DVD recorder
Here is the link to the manual if you need it; http://support.gateway.com/s/Manuals/CsmrEltrncs/8509547.pdf No remote codes, but: Gateway Technical Support at 800-846-2301, Monday through Friday, from 7:00 a.m. to 9:00 p.m. Central Time. Should be able to help Please post again if you get no joy from them :)
Mar 28, 2007 | Gateway AR-230 DVD Recorder
Gateway PC Remote Control Logo
12 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
