Question about LG 42PC5DC 42 in. Plasma HDTV
42pc5dc password reset
I have the language set up but I cannot receive the captions. How do I do this?
try going to onscreen menu , scroll around till you find a caption option and turn it on
some remotes for the tv will have that option in a button
Sep 17, 2016 | LG LCD TV Remote Control MKJ39927802...
Tip
How to Create a Password Reset Disk in Windows 7/Vista/XP?
Forgetting Windows password occurs more often than the users would like to think. So if you haven't created a password reset disk for your user accounts, it's time for you to take action. A password reset disk enables you to reset Windows password if your Windows password is forgotten. If you have no idea, just look at the following instructions.
Windows 7/Vista Password Reset Disk
If you are Windows 7/Vista user, you can create a password reset disk to reset Windows password as follows. Just 6 steps:
1. Enter Create a password reset disk in the Start search box.
2. Press Enter to pop up the Forgotten Password Wizard.
3. Insert a USB flash drive and click Next on the Forgotten Password Wizard.
4. Select the right device store the password information of the use account which you are logged on.
5. Enter the current user account password.
6. Wait while wizard creates the password reset disk. Click Next when it 100% finishes and click Finish to exit.
Windows XP Password Reset Disk
If you still use Windows XP, just take the following steps for reference to create a password reset disk to in case of the need of Windows password recovery. Just 4 steps:
1. Click Start > Control Panel > User Accounts.
2. Select the target user account and click Prevent a forgotten password on the left pane. The Forgotten Password Wizard will appear.
4. Follow the wizard to create a password reset disk.
Windows Password Reset Disk Tips
1. The created password reset disk should be kept in a safe place as anyone can use it to reset Windows password without any limitations.
2. When you enter a wrong Windows password, the Password Reset link will appear under the password box. You can simply click the link to start Windows password recovery with your created password reset disk.
3. If you forgot Windows password without such a disk, you can reset Windows password by a Windows password recovery tool like Windows Login Recovery.
on Jan 06, 2011 | Computers & Internet
Tip
Reset Windows 7 Password With Own Created Reset Disk
How to Reset Windows 7 Password
It is easy for you to create a password on Windows 7 to protect computer data. At often as you might forget Windows 7 password, which may result in serious data loss. In reality, forgetting Windows 7 password is not a big problem as long as you create a Windows 7 password reset disk in advance. A Windows 7 password reset disk can help you easily reset Windows 7 password when you are locked out of computer.
Part one: Create Windows 7 password reset disk
Before creating the password reset disk, please insert a USB flash drive or floppy disk in your computer.
1.Click Start button to select Control Panel.
2.Click on User Accounts and Family Safety, and then click on User Accounts.
3.Click on Create a password reset disk on the left of the following screen.
4.Click Next when the forgotten password wizard welcome screen appears.
5.Select your target device to create the Windows 7 password reset disk.
6.Type current user account password.
7.Click Ok when the password reset disk is created.
8.Click Finish when the completing screen comes up.
When the Windows 7 password reset disk is created, a file named userkey.psw will appear on your USB flash drive. Please remember to place the USB flash drive or the file in a safe place. Anyone can use it to reset your Windows password with it if he can get physical access to it.
Part two: Reset Windows 7 password with password reset disk
When you forgot Windows 7 password and locked out of computer, you can take out of the password reset disk to reset Windows password. Plug your password reset disk in computer, and then follow the below steps for Windows 7 password reset.
1. Log on your computer with the target Windows account.
2. Enter a wrong password in the welcome screen password box, and hit Enter.
3. Click OK when the message that the user name or password is incorrect comes up.
4. Click on Reset password on the following screen.
5. Click Next when password reset wizard welcome screen appears.
6. Select the target password reset disk and enter Next.
7. Enter and confirm your new Windows password and click Next.
8. Click Finish to close the wizard.
9. Log on Windows 7 with the newly reset password.
If you forgot to create Windows 7 password reset disk before locked out of computer
A windows 7 password reset disk can really save you a lot of trouble when you forgot Windows 7 password and locked out of computer. So don't forget a password reset disk before locked out of computer. If you forget to create Windows 7 password reset disk, you can use Windows Password Breaker Professional to help you reset lost Windows 7 password. This safe and reliable Windows password recovery software allows you to burn a bootable CD/DVD or USB flash drive to rest lost passwords for Windows 7/Vista/XP/NT and Windows Server 2008/2005/2000. You can log on your computer again within 5 minutes with this tool.
on Oct 29, 2010 | Computers & Internet
I have a "LG 42PC5DC - UL" that blinks 3 times "green" then back to "red standby"
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 31, 2014 | LG 42PC5DC 42 in. Plasma HDTV
Lg volume problems
The contacts between the carbon of remote and the rubberized button could be faulty.
Jul 19, 2014 | LG LCD TV Remote Control MKJ39927802...
I have a LG 42PC5DC TV. There are continuous horizontal lines going through the picture. Any ideas of what is wrong?
Is there any other electrical or electronic devices near the TV? If there are, move them away from the TV and see if that clears up those lines. IT could be some kind of interference. Or if there are video games hooked up,,disconnect them also.
Oct 30, 2013 | LG 42PC5DC 42 in. Plasma HDTV
Forget my password how to reset
What password you forgot, Windows password, Windows 8 or Windows 7 password?
How to reset Windows 8 password:
http://www.isunshare.com/windows-8-password/how-to-reset-windows-8-password-without-disk.html
How to reset forgotten Windows 7 password:
http://www.isunshare.com/windows-7-password/forgot-windows-7-password-no-reset-disk.html
Mar 11, 2013 | Acer Aspire 4720 Notebook
Immediately switches off when turning on.
you have power supply board issue.
try to look at the capacitors of have any bulged on top try to replace it..
Nov 11, 2012 | LG 42PC5DC 42 in. Plasma HDTV
42 inch LG plasma tv will turn on green led will flash 3 times and then turn off
Check and replace its main digital board. after replacement, somde adjustments have to be done, and you have to enter its service mode option to do it. Really it is a skilled work, that a customer who has no idea in electronics can do.
Aug 25, 2012 | LG 42PC5DC 42 in. Plasma HDTV
How to unlock the administrator password
Use windows password reset tool is the best way to recover admin password
Here are three tools for you.
Windows Password Reset( http://www.windowspasswordreset.net )
Windows Password Recovery Tool ( http://www.windowspasswordsrecovery.com )
Windows Password Crack( http://www.windowspasswordcracker.com )
Jul 19, 2012 | eMachines eM250-1162 Atom N270 1.6GHz 1GB...
LG 42PC5DC 42 in. Plasma HDTV Logo
19 people viewed this question
Computer Repairing
Computer Repairing
