Question about AEG Santo 7085 KG Side by Side Refrigerator
SPARE PARTS ICE DISPENSER TRAY
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
I have a kitchenaid 23cd.Icemaker doesn't work has 40# water pressure 5 deg in freezer water works to fill glass no water in ice tray unpluged for 24 hours
If the water dispenser is working and fill glass function is working but the ice maker section there is no water in the tray then its faulty ice maker valve.This is a twin valve.The valve is one unit,but has two sections one for water and one for ice dispenser.This valve is got faulty and not working for both sections so water is not entering the ice maker tray.
There is a water valve at the back of the ice maker.This valve controls the flow of water in the ice maker chamber.If this valve is not functioning as required then water will not enter the ice maker.This valve is at the back of ice maker connected to the water fill tube.It has to be replaced to clear this problem.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 01, 2011 | Refrigerators
Frigdaire model GLHS68EGW2 Ice dispenser does not work on side door. I pulled out the ice tray and held in the switch on the door and pushed on the ice dispenser on the door and no movement on the ice...
The paddle serves as an off and on control for your dispenser, auger and trap door that retains cold air in freeze when finished getting ice it also closes. If you notice something different I would want to rule that out first. Click Here=> GLHS68EGW2 Water Dispenser Parts Breakdown for a larger view, part 24 in photo. You May find the partts here also=> 241685701 or here=> 241685701
for additional assistance I will be here to help you, Thanks Sea Breeze
Aug 19, 2010 | Refrigerators
Whirlpool ed5gvexvdoo side by side When using the ice dispenser (cubed or crushed) it will not dispense. I have pulled the ice tray and the motor for running the dispenser arm runs. I have emptied the tray...
this maybe a problem with you auger motor may be stripped.open the door remove the ice bin.then hold the metal u shape auger arm and try to turn it by hand or have some one try to dispence ice if the u shape braket turn easy ny hand or if it stops turning when being held replace the auger motor.i hope this is some help,good luck you may also have to replaced the ice bin.
Jan 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice won't continue to drop from the dispenser
Check that the arm that is supposed to push the cubes out of the tray is working. If the tray heater is open and not working the ice cannot be removed from the tray because it is stuck - element has to be replaced. But given the high cost of parts it may be cheaper to just go out and get a new icemaker on ebay for relatively little
Aug 27, 2017 | True 598-TR1FRI1S Freezer Roll in One...
Ice dispenser jamming
There is a revised bucket that's made to prevent that.
If your refrig has a steel liner order WR17X11308
If it has a plastic liner order WR17X11315
Oct 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
AEG Santo 7085 KG Side by Side Refrigerator Logo
14 people viewed this question
Top AEG Refrigerators Experts
ashburton
Ian Jones
David Jewell
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
