Question about Franklin Chef Microwave Ovens
Installation manual for franklin chef fr1858-con
Model fr1858-con
Need manuel for magic chef steamer Of 2020 912
Try Googling (Magic Chef)(model)(manual) without parens.
Jul 04, 2017 | Magic Chef Microwave Ovens
How do you install light bulb on mcw1611 magic chef??
I'm not finding a Magic Chef model MCW1611, but I do see they have models like MCM1611B and MCM1611ST. Maybe it's one of those?
Either way, I would suggest checking your owner's manual to see if it mentions bulb changes. If for some reason you don't have yours, you should be able to download it or a similar one here. https://mcappliance.com/manuals
If the manual doesn't cover bulb changes, then you would need to remove the outer cover to get to the bulb, usually located on the right side near the magnetron.
Feel free to contact me for further info.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | Magic Microwave Ovens
Can you use metal pan if only on convection setting?
Microwaves penetrate most materials except metals which offer a ready path to the internal surfaces, so you would expect to see occasional flash overs using a metal pan, sudden surges like this will shorten the life of the magnetron.
Apr 21, 2014 | Franklin FR187S-CON Stainless Steel...
PAPER DIRECTIONS
That FCC number means it was made by Daewoo, but it may have a Magic Chef or other brand name.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
For Magic Chef in Canada call 866.587.2002
Jun 05, 2013 | Magic Chef Microwave Ovens
Trying to locate microwave for odd size built in
It or any other counter top microwave can be placed into a "cubby hole" type of installation, as long as there is enough space on all sides of the unit for ventilation, as specified in the owner's manual.
(Yours is here)
Plus, there must be an opening for air flow.
Jan 29, 2010 | Magic Chef MCD1311ST Microwave Oven
I have an magic chef mvp V microwave and have just put in new cabinets. Do i need to cut an air vent in my cabinets or does it vent through the front?
Consult your installation instructions for that information.
Jun 05, 2009 | Microwave Ovens
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Franklin Chef Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Franklin Chef Microwave Oven Expert? Answer questions, earn points and help others
