Question about Treadmill Doctor Proform Razor 400 Elliptical Console
My proform razor 400 elliptical makes a horrible loud squeak when Im using it. Is it the belt?
Whenever I am using the elliptical it makes a horrible loud squeak. its ear shattering.
Vacuum squeaking loudly!!!Help!!!!
Most likely has a bunch of hair wrapped around the beater bar. Get some scissors, razor knife and some needle nose pliers. Turn the bottom up and remove the cover and start digging the hair out. You may need a new drive belt too.
Nov 07, 2015 | Vacuums
My Proform 6.0 ZE elliptical is draining new batteries within hours and humming. It makes LOUD popping and static sounds when using the AC plug in.
DEAR
AT FIRST YOU COUNT YOUR BAT AND MULTIPLY 1.5 THEN YOU USE A ADAPTER AC TO DC WITH SAME VOLTAGE LIKE 6 V OR 9V DC
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 21, 2017 | Proform Pro Form 6.0 ZE Elliptical
Proform hybrid trainer squeaks - elliptical portion only. Everything tight. What do I do now?
Locate the site of the sqeak. Then spray WD40 or similar spray lubricant thoroughly in and around the screws in that area using the straw attachment. I did just that and it took care of the problem.
Aug 07, 2013 | Proform Hybrid Trainer Elliptical
I have a 390 proform Elliptical and it's is locked up. When I get on it, the pedals are tight and I can not move them.
There may be a problem with the belt inside the machine.
It has to be taken apart to assess.
Jul 14, 2013 | Proform 395 E Elliptical
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
Proform XP110 R recumbent bike makes clanking noise.
I have the same problem with my XP 110. After taking the ENTIRE thing apart and independently testing every single moving mechanism, I found out that it wasn't the motor, pedals, armbars, or any internal mechanism. Instead, it was the front stabilizer foot that made the annoying noise. There is a plastic mechanism around the front stabilizer legs that holds the front wheels in place (for moving the elliptical). Whenever a rotation forward occurs, the plastic squeaks and the noise resonates to make it sound like the pedals or motor is squeaking. I am still trying to find a solution to fixing the feet, but may end up ordering a new set from the manufacturer. Good luck with your elliptical!
Mar 22, 2009 | Exercise & Fitness
Treadmill Doctor Proform Razor 400 Elliptical Console Logo
49 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
