Question about Konica Minolta Bizhub-200 Minolta Printer
Konoka bizhub 200 need to connect to my computer
I can not get it to print or scan
  • Konica Minolta Master
  • 6,161 Answers
Have you given it its IP address? Is set up on a network or just a single computer? If single computer will need a cross over cable. Cat 5 do you print driver disk or down load from Konica Minolta web site download driver are free.
Posted on Jan 06, 2015
SOURCE: Scanning Problems
mail server issue. check your outgoing mail server. Most smtp depends on your isp. for instance, use smtp.sbcglobal.net for at&t isp. if you have an exchange server use your exchange server's outgoing mail.
Hope this helps!
chris
www.willhelpu.com
Posted on Mar 18, 2008
SOURCE: Can't Scan anything on a BizHub C550 to 5 pcs on the same network
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Posted on Jan 06, 2009
SOURCE: Socket Connect Error on BizHub C550
Select HTML on the Pagescope login page.
Posted on Mar 09, 2009
  • 24 Answers
SOURCE: Bizhub c350 will not scan to hdd
Easiest way is to change to SMB scanning which will give you direct scanning to PC or server. Create a new address in the machines address tab in the browser add the (must be a fixed) ip address of the machine it is going to with the folder name, user name and password and it will work a treat.
Posted on Jun 25, 2009
DocuSystems
  • 10 Answers
SOURCE: when typing 192.168.1.99 in the address book of IE
Bizhub needs a frmware upgrade. There was a firmware issue which caused this when .NET Framework 3.0 was installed on the PC.
Posted on Aug 05, 2009
My printer is not connected right
Do you mean router or switch?. Is this network Bizhub 200? Do have print drivers if not go to konicaminolta web site a down load FREE
Mar 20, 2014 | Konica Minolta bizhub 200 Printer
Bizhub 224e won't print from computer
Is this machine on a network? if so can other computers print?(IF others can not the machine) If this is a single computer are you using a crossover Ethernet cable. Are you sure the proper drivers are installed go to Konicaminolta to get latest drivers free.
Dec 19, 2013 | Minolta bizhub 200 All-In-One Printer
How to get rid of vertical lines in scanned documents in bizhub 200?
Open the top cover of the machine and clean the small glass on the left hand side. Good luck.
Dec 27, 2012 | Konica Minolta bizhub 200 Printer
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Aug 28, 2009 | Konica Minolta bizhub 200 Printer
HDD Scanning and Access
help.bt.konicaminolta.ca
You will need the Box Utility.
Apr 06, 2009 | Konica Minolta bizhub C250 All-In-One...
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
96 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
