Question about Pride Jazzy 1103 Ultra Standard Power Chair
When I turn it on the indicator lights flash but the chair will not move
The batterys are full charge
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
The number of lights lit and/or the number of times they flash help determine what the problem is, and there is a chart for that in the manual. If you have lost yours, you can find one online.
Posted on Jun 09, 2014
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 175 Answers
SOURCE: the battery is charged but the lights just flash
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
Good luck.
Posted on Jul 11, 2009
  • 13 Answers
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Posted on Feb 02, 2010
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Posted on May 18, 2010
Testimonial: "That was the problem, Thanks !!!"
  • 175 Answers
SOURCE: all lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
These will tell you what the fault is; repost with more information.
Posted on May 23, 2010
When plugged in lights indicate full charge,when I pull plug all lights go off,won't move this is a jet 3
Something between the batteries and the motors and joystick is interrupted. Recheck fuses and connections.
Aug 08, 2014 | Jet 3 Ultra Power Chair
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
Powerchair doesn't move 1 red light blick's on the leftside of VSI
John,
This flash code indicates that the battery needs charging or there is a bad connection to the battery. Check the connections to the battery. If the connections are good, try charging the battery.
This flash code can be seen at the following link:
With the battery voltage too low the chair will not move. Hope this helps.
Jan 08, 2011 | Jet 7 Portable Power Chair
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
Dec 20, 2010 | Pride New Jazzy 600 Power Wheelchair by...
Chair is charged up. When we turn it on the lights, top and bottom set, flash on and then goes off.It shows a full charge when it flashes. Battery should be good,It's not that old.
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 31, 2010 | Pride Jazzy 1103 Ultra Standard Power...
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES,...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
My suns Quickie P320 (dual battery) requires very
Rapid discharge usually is a sign of weak batteries, and they should be replaced if the charge indicates that they are full after charging for several hours, and then dissipate rapidly.
If your not getting a full charge indication after several hours, then you need to check the charger to make sure it is putting out about 28 Volts DC. If it is, then it is for sure the batt's.
The sweeping lights should not occur when the chair is off the charger. They sweep while on charge to tell you that it is charging and you can't move the chair. If they sweep while off the charger, turn off and restart and it should go. If not, call a tech. rep. for Quickie.
Sep 29, 2009 | Quickie Wheelchairs Health & Beauty
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
85 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
